PTO crank seals causing high idle??? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 6 (permalink) Old 02-02-2008, 09:17 AM Thread Starter
Leonard Evans Body Shop
paintexpt's Avatar
Please help me to understand this, I see alot of people saying a crank seal would also cause high idle, not that that is my problem, I just want to understand this, as obvoiusly its not like an automotive engine, I just do not see how that could affect the idle
1996 Ski Doo Formula 500 SL
1995 Polaris Indy 500 EFI 136
94 Ski doo Formula Z 583
1980 Artic cat Trail cat 340, what a fun old sled
1986 Polaris Indy 400
paintexpt is offline
post #2 of 6 (permalink) Old 02-02-2008, 09:40 AM
Above The Arctic Circle
lrnnorth's Avatar
when you have an air leak it causes a lean mixture in the cylinder which in turn will make it rev too high at idle. If you have an air leak you should be able to tell by your jetting.
01 Polaris RMK 136"
- 01 600 VES Engine - Uni Air Filters
- Sno Stuff Rumble Pack - Powermadd Boost Bottle
- Custom Painted Hood - Powermadd Bar Riser
- EPI Pro Series Clutch Kit - Xtra-10 rear suspension
01 Yamaha VK III 540 (The TANK)
Out Of Commission Till Next Year
lrnnorth is offline
post #3 of 6 (permalink) Old 02-02-2008, 09:48 AM
Hiberna Somnium
Jim Jessup's Avatar
Leaking crank seals cause the air/fuel mixture to LEAN out, as the mixture leans out the engine revs higher because the mixture is burning so efficiently. However since the mixture is buring so efficiently it also burns very HOT and at higher RPMs the engine can't sustain the extra heat and the piston will likely seize(usually on the exhaust side). The reason the mixture will lean out is because the leaking seal will let more air into the mixture after its forced into the crankcase. Try running your lawnmower or car out of gas and you will hear the RPM go up and peek then die. Same thing with your engine except there is still enough fuel in the mixture to keep it running.
The fleet...
1989 Ski-Doo Formula Mach 1
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
1999 Ski-Doo Formula S
Jim Jessup is offline
post #4 of 6 (permalink) Old 02-03-2008, 04:40 AM
Three ways to tell if you are running lean.
1. Popping at the exhaust
2. Plug electrode color is gray or white.
3. The engine suddenly has a lot of pep that was never there before. (they always run their best just before failure)
Either one is a good indicator, although, # 1 usually means that the damage has already progressed to the point of needing repair immediatly.
To test for a air leak, you can use starting fluid that you spray around the crank seals, the carb mounting flanges (boots) and the head and base gaskets. This is done with the engine running and if the rpms go up, you have an air leak. Do not run the engine any longer, but get it fixed right away.
post #5 of 6 (permalink) Old 02-03-2008, 09:55 AM Thread Starter
paintexpt's Avatar
excellent explaination, I dont think thats the problem, good thing to watch for tho, I just have to get out there and figure it out, was just curious as to what this meant, but will be the first thing I will check as it is so easy, I do see some fuel seeping from one of the carbs where the fuel line connects on the side of the carb body, it is like a little elbow block that the line hooks to, not sure what to do about that or if I will need another carb body
post #6 of 6 (permalink) Old 02-03-2008, 04:05 PM Thread Starter
paintexpt's Avatar
I think it is my cable as I have checked everything,, cleaned the carbs, sprayed brake kleen all around and no difference, but it appears that It seems to could possible be over oiling, im buying a new cable from DennisKirk - Production Website Home page,
