grinding reverse even after linkage adjustment - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 6 (permalink) Old 02-01-2008, 01:40 AM Thread Starter
Denwa's Avatar
Question grinding reverse even after linkage adjustment
2000 550 trail touring sled. New gears, rebuilt motor. I picked this sled up for my mom recently and other than rejetting the carbs for our area, no problems except for the reverse.
The gears grind when you hit the gas in reverse. I adjusted the linkage and it still grinds, though when on a track stand it will not grind. Can't adjust the linkage any further out as it starts effecting the fwd gears.
Any ideas?
Denwa is offline
post #2 of 6 (permalink) Old 02-01-2008, 05:21 AM
Open it up and look in there, possibly need to reshim or replace gears.
post #3 of 6 (permalink) Old 02-01-2008, 02:01 PM Thread Starter
Denwa's Avatar
It looked all right in there when I opened it up the other day. Gears and chain are definitely new. What exactly should I be looking for in regards to the reverse? How do I tell if I need shims etc?
Denwa is offline
post #4 of 6 (permalink) Old 02-02-2008, 06:35 AM
That you will have to check with someone else, I do not have the experience with a reverse setup.
post #5 of 6 (permalink) Old 02-03-2008, 02:31 PM
Mr Polaris
big bore king's Avatar
Check your belt deflection. If its on the tight side it will cause exactly the problems you describe. It wont do it on the stand because there is no load on the drivetrain. Deflection should be no less than 1.25" with reverse.
Anything stock pretty much sucks!
2001 Polaris 600xcsp(sks) 1.5 paddle
2002 Polaris 500xcsp 1.25 paddle
1996 Polaris Ultra SP
2000 Polaris XCR 120
2000 Ski Doo Formula 380
2000 Polaris trail blazer 250.
2001 Yamaha Big Bear 400
2000 Honda TRX 90
1995 Jeep Wrangler
2008 John Deere 2520, FEL, snowblower, cab
big bore king is offline
post #6 of 6 (permalink) Old 02-04-2008, 03:26 AM Thread Starter
Denwa's Avatar
OK thanks, I'll have to figure out how exactly to do that, but I suppose it can't be to hard.
Denwa is offline
