Old 01-20-2008, 12:53 PM   #1 (permalink)
snonut12
Variable exhaust
Sorry if it's a stupid question but exactly what does VES do that is different from non VES sled? My guess it is something to do with power but am not sure. I'm trying to determine how the XC differ from XCSP.
Stephen
snonut12 is offline   Reply With Quote
Old 01-20-2008, 08:56 PM   #2 (permalink)
VES basically opens up the exhaust port at the right time, changing the power band of the engine.
Old 01-20-2008, 08:57 PM   #3 (permalink)
huskysled
"It's Only Money"
huskysled's Avatar
Check polarisman.com for the differance between XC and XC SP. Some years it was only additional items like seat pads etc. It had nothing to do with the VES.
The VES (Veriable Exhaust System) monitors exhaust pressure in the cylinder via a diaphram/spring. The regulated pressures, unlike a non-VES motor, result in better/cleaner burns in the cylinder creating added HP. The newer HO engines then came out with vaccum controlled VES and now electronic assisted VES. Ski-Doo originally came out with this type system in the early 90's (Mach Z and MX Z).
However, small engine guy is the resident expert. I only think I know a little.
Cheers
05 Polaris 600 XC Anniv.
98 Polaris 700 XC
73 John Deere 600
06 Polaris 450 Sportsman 4x4
01 Polaris 250 Trailblazer 2x4
03 Triton 2-Place Enclosed Trailer
88 Hercules 2-Place Open Quad Trailer
87 Ducati Paso 750
07 34' Itasca Sunstar Motorhome
03 Ford F-350, 6.0, 4" lift, Banks Monster Exhaust
"He Who Dies With The Most Toys, Wins"
huskysled is offline   Reply With Quote
Old 01-20-2008, 08:58 PM   #4 (permalink)
huskysled
"It's Only Money"
huskysled's Avatar
Dang, SEG beat me to it. Thanks, SEG
98 Polaris 700 XC
73 John Deere 600
87 Ducati Paso 750
Old 01-20-2008, 10:12 PM   #5 (permalink)
You got it right, though, Huskysled!
Old 01-21-2008, 02:39 AM   #6 (permalink)
lrnnorth
Above The Arctic Circle
lrnnorth's Avatar
So do the standard motors without valves make more horse power than the same size engines with the ves?
01 Polaris RMK 136"
- 01 600 VES Engine - Uni Air Filters
- Sno Stuff Rumble Pack - Powermadd Boost Bottle
- Custom Painted Hood - Powermadd Bar Riser
- EPI Pro Series Clutch Kit - Xtra-10 rear suspension
01 Yamaha VK III 540 (The TANK)
Out Of Commission Till Next Year
lrnnorth is offline   Reply With Quote
Old 01-21-2008, 07:27 AM   #7 (permalink)
NO, VES make more, because they "self tune" with different RPM's.
Old 01-23-2008, 03:31 PM   #8 (permalink)
Indy600
Dont forget to clean the valves on a yearly basis. I got lazy last year and then remember that I had to do it this year. I had a ton of crap on there.
Indy600 is offline   Reply With Quote
Old 01-23-2008, 04:40 PM   #9 (permalink)
lrnnorth
lrnnorth's Avatar
Thats what i thought but i was wondering because it seems like all the aftermarket compainies' hp increase claims seem to be larger for the big-block motors. Like for a pipe for the small block is 8 hp and the big block is 10 hp. Why is this?
01 Polaris RMK 136"
Old 01-24-2008, 11:07 AM   #10 (permalink)
H2oSprayer
Any chance of a tutorial on how to remove and with what and how to clean?
H2oSprayer is offline   Reply With Quote
Old 01-24-2008, 01:48 PM   #11 (permalink)
http://www.snowmobileforum.com/engin...-tos-here.html
Old 01-24-2008, 02:29 PM   #12 (permalink)
H2oSprayer
Originally Posted by RJ Gleason
Thanks for the link. There is a ton of great stuff there. But I didn't see anything about cleaning the VES valves. Did I overlook it?
Old 01-24-2008, 03:39 PM   #13 (permalink)
Indy600
It really is a piece of cake. I can not remember the size of the wrench (either 8 or 10mm) there are 4 bolts on each valve under the spring housing (black). You just have to remove those 4 bolts and then just slide the valve right out. If it is all gooked up, it will be difficult to slide out. There will be a gasket under there. Mine was a light green. Check it for cracks or tears. If it is bad, get a new one. A couple bucks for the gasket. Dont worry about putting it in the wrong way, there is a locator pin on it so that you can not put it in the wrong way. Pulling the bolts is a little tedious, unless you have a crows foot ratchet. I do not have one of those. your cramped up hands will make you appreciate it all the more. When you get it out you can use either a brillo pad or wire brush. I would be careful with scraping the valve though.
Old 11-02-2009, 04:20 PM   #14 (permalink)
amynjimmy
amynjimmy's Avatar
Cleaning the VES should be done yearly???? I dont know if mine has ever been done. how can u tell if it needs to be done?
[SIGPIC] Drive it like ya stole it!!!!
amynjimmy is offline   Reply With Quote
Old 11-02-2009, 05:14 PM   #15 (permalink)
If there is any carbon build up on the guillotine, it needs cleaning.
Old 11-02-2009, 08:39 PM   #16 (permalink)
NonStikCookWare
The way it goes
Once a year is the minimum! i doo mine every 500 miles. And if u want better fuel milage and better pull, then tighten your ves down all the way, and turn it out two notches (this is also the best setting for 660 drag racing)
NonStikCookWare is offline   Reply With Quote
Old 11-02-2009, 10:56 PM   #17 (permalink)
BC_Dan
The newer valves are not adjustable... the only adjustment is to swap springs. There are different colored springs for different altitudes.
Old 11-03-2009, 01:27 PM   #18 (permalink)
amynjimmy
amynjimmy's Avatar
im a little new at the VES thing....I have no idea how to even begin
Old 11-03-2009, 01:43 PM   #19 (permalink)
BC_Dan
I posted a thread on removing and cleaning, it has pictures
hope that helps!
http://www.snowmobileforum.com/polar...-assembly.html
Old 11-03-2009, 02:37 PM   #20 (permalink)
NonStikCookWare
The way it goes
The best thing i ever did for taking my ves out of my 2001 was cut the end off the wrench and weld it back on 90 degrees. Now i can get a full turn on the bolt instead of little quarter turns lol
