Belt adjustment - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 5 (permalink) Old 01-20-2007, 10:09 PM Thread Starter
maineack bob's Avatar
Question Belt adjustment
Hi Everyone i was just wondering how high/low in the secondary clutch should the belt on my 1997 xcf be right now it is about 2-3mm down inside of the secondary clutch. If this is to low how would i go about adjusting it, there are 3 screws and a plate with a dial that i know adjust's the belt but do i just loosten the bolts ant turn the dial because i tried this and wheni try ti turn it it is very hard unless i push the belt manually down into the clutch. Is there any proceadure involved if so it would be very helpfull
P.S. I do not have my owner's manual, and that is where it tells you how to do this lol.
maineack bob is offline
post #2 of 5 (permalink) Old 01-21-2007, 06:51 AM
Mr Polaris
big bore king's Avatar
Should be a 1/16 above the sheaves, and you are doing it corect. By pushing the belt down you are taking pressure off the pins behind the plate and the plate will move eaisier.
Anything stock pretty much sucks!
2001 Polaris 600xcsp(sks) 1.5 paddle
2002 Polaris 500xcsp 1.25 paddle
1996 Polaris Ultra SP
2000 Polaris XCR 120
2000 Ski Doo Formula 380
2000 Polaris trail blazer 250.
2001 Yamaha Big Bear 400
2000 Honda TRX 90
1995 Jeep Wrangler
2008 John Deere 2520, FEL, snowblower, cab
big bore king is offline
post #3 of 5 (permalink) Old 01-21-2007, 09:43 AM Thread Starter
Thanks Big Bore King that really helped. I wasn't shure if i was doing it right.
Also i am using a belt with teeth on top and bottom and the top teeth are about 3/16 of an inch high so where do i measure
the 1/16 of an inch, from on top of the top teeth or between them.
post #4 of 5 (permalink) Old 01-21-2007, 02:56 PM
Mr Polaris
Top of the cog.
2000 Honda TRX 90
1995 Jeep Wrangler
post #5 of 5 (permalink) Old 01-21-2007, 03:57 PM Thread Starter
Ok Thanks again Big Bore King
