Oil leak - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 11 (permalink) Old 12-15-2006, 05:35 PM Thread Starter
born2sled's Avatar
Oil leak
I saw dirt was sticking to everything when I uncovered the snowmobile so I looked into it and there's oil under the seat and all over. So i took the gas tank off and it looks like right where the hose hooks to the oil resivor there's this rubber (plastic??) piece, it looks like it's leaking around that thing. Not sure what it's called but it has two wires running from it. My buddy has the same problem with his PRO X so thinking it's the same problem.
Has anyone else heard of this, and is there a fix for this or am I going to have to take that piece off and get a new one? or wouldn't that fix it either?
born2sled is offline
post #2 of 11 (permalink) Old 12-15-2006, 05:58 PM
IndianRvrShiver's Avatar
Sending unit for the low oil warning lamp!?
IndianRvrShiver is offline
post #3 of 11 (permalink) Old 12-15-2006, 07:46 PM Thread Starter
born2sled's Avatar
I thought of that but wouldn't that be part way up the resivor so it'd tell you before you were completely out? I'll try to post some pics so you can get a better idea of what i'm talking about....
ID:	5667   Click image for larger version
ID:	5668   Click image for larger version
post #4 of 11 (permalink) Old 12-16-2006, 02:04 PM
Not sure?? Is it a switch that might shut the engine down when you run out of oil???
post #5 of 11 (permalink) Old 12-16-2006, 05:37 PM
Mr Polaris
big bore king's Avatar
Low oil level sending unit. These are known to leak. You can take the tank off, remove sender, clean the area good use silicone on sender, reassemble everything, and you will be good as new. I have had to do it to all of my Polaris's. There is a TSB out on this, can't find the #.
Anything stock pretty much sucks!
2001 Polaris 600xcsp(sks) 1.5 paddle
2002 Polaris 500xcsp 1.25 paddle
1996 Polaris Ultra SP
2000 Polaris XCR 120
2000 Ski Doo Formula 380
2000 Polaris trail blazer 250.
2001 Yamaha Big Bear 400
2000 Honda TRX 90
1995 Jeep Wrangler
2008 John Deere 2520, FEL, snowblower, cab
big bore king is offline
post #6 of 11 (permalink) Old 12-17-2006, 01:15 PM Thread Starter
born2sled's Avatar
alright i'll have to try that, thanks for the info
post #7 of 11 (permalink) Old 12-17-2006, 04:22 PM
Runnin Against The Wind!
SnowRida's Avatar
What he said. But I wouldn't puy it past locky cause he's alway's looking for oil caps!
SnowRida
Yamaha V-Max SOLD
02 MXZ 600
97 Polaris Indy Trail Touring
04 REV 600 HO Adrenalin
SnowRida is offline
post #8 of 11 (permalink) Old 12-17-2006, 07:55 PM
RMK 600's Avatar
worked for our 99 xc 700 had the same problem
2006 600 RMK
YOU SHOULDN'T CRITICIZE SOMEONE UNTIL YOU HAVE WALKED A MILE IN THEIR SHOES; THAT WAY YOU ARE A MILE AWAY AND YOU HAVE THEIR SHOES!
RMK 600 is offline
post #9 of 11 (permalink) Old 12-17-2006, 08:49 PM Thread Starter
born2sled's Avatar
How does this sending unit come off? I haven't had time to look real close but does it spin out or is there a washer inside that it tightens up against or how does it work?
post #10 of 11 (permalink) Old 12-18-2006, 09:59 PM Thread Starter
born2sled's Avatar
Or did you mean just silicone it while it's on the resivor? Otherwise I looked at it and when I tried to spin it the whole thing just spun through and I didn't want to break it trying to get it off. And if I have to take the sending unit off from the resivor, how do I do that?
thanks again
post #11 of 11 (permalink) Old 03-02-2008, 05:38 PM
Did you ever get this figured out? My sled has the same problem and I'm going to have to fix it. Any advice will be greatly appreciated.
-Sam
SammyK is offline
