1998 Polaris indy 500 suspension questions - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 6 (permalink) Old 11-24-2006, 04:08 PM Thread Starter
Hey out there. I could use some help with my Indy 500. The problem is that the suspension has no stifness. you can push the suspension down b hand and it won't come back up. It won't support any weight at all (always bottomed out). The springs appear to be fine, and there isn't any leaking evident from shocks. I want to fix it myself, but i don't want to buy any parts that don't require replacement. Any ideas? (extra 10)
jeffk49738 is offline
post #2 of 6 (permalink) Old 11-24-2006, 08:00 PM
RMK??'s Avatar
your shocks are out of gas. You wont see any leaks, they fill the shocks with dry nitrogen, unable to detect, its a gas...
RMK?? is offline
post #3 of 6 (permalink) Old 11-24-2006, 08:05 PM Thread Starter
Oh, i thought the factory ones were hydraulic. So would it be both shocks? And are the springs more than likely ok?
Thanks in advance
post #4 of 6 (permalink) Old 11-24-2006, 08:25 PM
RMK??'s Avatar
I had a 98 xcr 600 with the extra 10, it had gas shocks, assuming yours does as well?? They should say on them, what type they are, check it out, if they are gas, they need to be recharged, if hydolic, just replace them, they're cheap.
RMK?? is offline
post #5 of 6 (permalink) Old 11-25-2006, 07:45 AM
replace all the shocks front and back and if you weigh over 200lbs put in heavier torsion springs
kimgor24 is offline
post #6 of 6 (permalink) Old 11-25-2006, 11:52 AM
You should check your rear shock if you have the one that has a little screw at the bottom of the body, It may have backed it self out. This screww adjusts the compression rate on the shock. Not sure if your sled has this or not but some did. Its a little needle valve so just screw it back in with a flat screw driver to adjust the stiffness of the ride.
If you don't have this then you either have a throw away shock or a rebuildable fox unit in there. If this is the case then take out and show your dealer they will tell you what to do.
brad62 is offline
