550 indy starter problem - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 5 (permalink) Old 04-20-2017, 02:29 PM Thread Starter
Ranb's Avatar
The last day I rode my 2014 550 Indy LXT back in January (in Minnesota) the starter failed to engage all the way and made a terribly loud screeching/grinding noise when I hit the starter button. I let go then gave it another try, the second time it engaged normally and the engine started and ran fine. I put the sled away that night for the year then forgot about it when I flew back home to WA.
The battery was in good condition and fully charged as far as I know. When the starter engages properly the engine turns over rapidly. Might there be a loose connection on the starter that keeps it from fully engaging? Thanks.
Ranb
Polaris 550 Indy LXT 2-seat
Ranb is offline
post #2 of 5 (permalink) Old 04-21-2017, 01:48 AM
Quoted: 102 Post(s)
I would suspect the bendix that engages the ring on the primary is sticking. Sometimes a good cleaning will clear that up.
BC_Dan is offline
post #3 of 5 (permalink) Old 04-21-2017, 07:05 AM
Quoted: 143 Post(s)
Yeah just pull it and see whats up?
I beet a good cleaning and it will be fine!
If you feel better about it, take in to your local auto electric repair shop!
They can check out the bushings and brushes?
kccats is offline
post #4 of 5 (permalink) Old 04-21-2017, 02:40 PM
TheBearAk's Avatar
Quoted: 54 Post(s)
Probably just needs a cleaning. The spring also can get mangled and is replaceable. 50 cents for that part.
Could also be that the gears were just in the wrong position and just grind that one time, may never happen again.
Or it could be that the bolts holding the starter on have come loose. Tighten it all up and see what happens.
1995 Skidoo Summit 583 LQ
1985 Skidoo Tundra 250F
1999 Arctic Cat Jag 340F
Currently working on:
TheBearAk is offline
post #5 of 5 (permalink) Old 04-21-2017, 03:59 PM Thread Starter
Ranb's Avatar
Thanks guys.
Ranb is offline
