I need to know if a 2002 rmk 800 clutch fits on a 2000 700. Both libertys. iI put it on with correct weights and spring and fits fine but is it really OK? Also my belts way to tight now
The 800 may have had a wider roller, but with the right springs/weights, it should run just fine. If it's the wide roller 800, those were a bit stronger than the narrow roller clutch. I've seen both on 800's.
Belt tightness is a function of the secondary, you may have to adjust it a bit to open the movable sheave to get the proper deflection.
Related Threads
Snowmobile Forum
630.8K posts
58.1K members
Since 2002
