Go Back   Snowmobile Forum: Your #1 Snowmobile Forum > Automotive and Other Sport Forums > Offroad Forum
Old 06-19-2006, 10:13 PM   #1 (permalink)
snowmonkey
snowmonkey's Avatar
Gas ratio?
What gas/oil ratio should i b running in my late 90s honda xr100? i didn;t think it was nessicary untill i saw the thing about oil in the gas in that KX250. I just put in 1 quart penzoil 20w50 oil for every gallon of gas. It seemed 2 run pretty sluggish and produced quite a fair amount of smoke. Is this normal? Please help.
1988 Polaris Indy Tail 440 Fan-only 8700 miles
snowmonkey is offline   Reply With Quote
Old 06-20-2006, 05:10 AM   #2 (permalink)
SnowRida
Runnin Against The Wind!
SnowRida's Avatar
Dude, that oil your using is 4 stroke oil. You don't mix with that! You have to use 2 stroke oil. You should run a mixture of 32:1, which is 16 ounces oil to 4 gallons of gas. Use Klotz or amsoil 2 stroke. Drain what you have in there now and flush out the gas tank. 32 ounces of 4 stroke oil to a gallon of gas??? What were you thinking??????
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 06-20-2006, 06:02 AM   #3 (permalink)
Do what Snowrida says NOW!!! regular oil will SEIZE the ENGINE! Drain the fuel/oil out and put in a good 2 stroke mix!
Old 06-20-2006, 06:14 AM   #4 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
DO IT NOW!!
Old 06-20-2006, 09:44 AM   #5 (permalink)
ITriumph
F.K.A. MOUSE72
ITriumph's Avatar
My friend did that when we were kids. Totally screwed thawt motor right up
snow and ice imagery
extended forecast for Alanson
And on the eighth day, god created snowmobiles .
ITriumph is offline   Reply With Quote
Old 06-20-2006, 10:45 AM   #6 (permalink)
IndianRvrShiver
Bet there weren't no skeeter's around when that sucker was runnin'!!
Old 06-20-2006, 02:32 PM   #7 (permalink)
letitsnow
I am the Walrus
letitsnow's Avatar
just ignore these guys, they are a little dense.
an XR 100 is a 4 stroke, there is no need to mix any gas, just put straight oil in the crank case
My Pics
1999 Arctic Cat ZL 440
1994 SkiDoo Mach 1 583
1995 Honda CR 125R
1982 Camaro w/ 355
Old 06-20-2006, 03:05 PM   #8 (permalink)
SnowRida
SnowRida's Avatar
What a cotton pickin minute!
If your bike is a 4 stroke (find out) then just run straight gas, no oil to mix. The 4 stroke oil will go in your crank case, usually around 24 ounces.
Now if the bike is a 2 stroke, mix as stated above. Hope this clears it all up.
Still, drain that gas and flush out the tank. Start fresh before you ruin your engine.
SnowRida
Yamaha V-Max
02 MXZ 600
Old 09-16-2006, 09:47 AM   #9 (permalink)
gettr
Yep, the XR's are 4 strokes...... I'll bet it smoked pretty good and ran like.... well not good? I hope you don't use that same 20w50 in your sled.... It ain't gonna last long.
gettr is offline   Reply With Quote
Old 09-17-2006, 08:52 AM   #10 (permalink)
mx and sled 41
mx and sled 41's Avatar
yup... brother and sister share an xr 100... no mixing gas with oil at all... and you better drain your gas tank or else you'll blow your motor pretty good... just unplug the hose at the bottom of the tank from the on/off switch, then tuwn your gas on and drain it into a can or something-then despose of it, its no good for anything anymore, and if you do have a 2 stroke, mix it with a 2 stroke mixing oil-not engine oil!
"slidin rear, back window, so it's an easy reach to where my cooler keeps 'em iced down cold"
truck- 1998 chevy 1500 extended cab 4X4 Z71 package fully loaded 5.7L vortec
sled- 1989 Polaris Indy 500 Special (blue clutch spring) FOR SALE!!!!!
2007 Honda CRF 230
2003 Honda CRF 230
mx and sled 41 is offline   Reply With Quote
