04-15-2011, 01:25 PM
1979arctic
handlebar risers
im looking on getting handlebar risers for my 94 xlt just looking for some insight on what size to get
04-15-2011, 02:49 PM
3" seems to be about as high as you can go without extending your cables..
99 700 RMK
99 700 XC
96 XLT RMK (can't bring myself to sell it)
05 900 RMK 166
04-19-2011, 09:17 AM
how tall are you ? i'm 6'3", i use a 6" riser and bars with a 2" rise
04-19-2011, 12:43 PM
1979arctic
im 6 foot
04-19-2011, 02:37 PM
ride till your broke
im 6'11" and am going 9in this summer!!
that sounds weird!!! haha.
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e-mint!!
04-19-2011, 08:18 PM
josh
I'm 6 ft and i have 6" risers on mine and its decent for sitting and decent standing, its hard to get one thats great for both sitting and standing.
Can it! Then you'll at least sound like your keeping up!
04-19-2011, 09:17 PM
agreed^^
u cant see your guages as well either.
current sleds
04 rev800ho gade
95 formulaIII 600
04-20-2011, 12:50 AM
If you go 9", consider doing something to beef up the steering column. With that much leverage, it's very likely that you will bend/break something if you don't.
04-20-2011, 07:05 AM
how would i do that??
never done it, please educate me.
current sleds
04 rev800ho gade
95 formulaIII 600
04-20-2011, 10:26 AM
On some of the Polaris sleds, there were aftermarket brackets that gave additional bracing above the hoop. There are also after-market steering columns made of stouter material. Some steering columns are hollow at the top. I have read about putting additional bracing inside the column to strengthen it. Some guys have even cut the top of the column off, added bracing, then rewelded the top.
When I had an Edge RMK, I did the first; added a bracket with an additional bearing above the hoop. It worked awesome, but the company that sold those no longer sells 'em. I have a Rox 5" on my 700 and am sometimes nervous because I have not done anything extra to strengthen the column.
I'm definitely not a Ski-doo guy, and only ride with one guy that rides one (a Summit 1000), so I don't see a lot of broken ones. But with 9" of rise, that's a ton of leverage to be adding, so it would be a good idea to ask around and see how well the steering column handles the additional torque. Just my humble opinion
04-20-2011, 10:30 AM
i see, thanks alot.
good info!!
current sleds
04 rev800ho gade
95 formulaIII 600
04-20-2011, 11:53 PM
1979arctic
should i get straight bars if i would go 6 inches?
04-21-2011, 12:19 AM
For your xlt, you can unbolt the bars from the steering column and put a piece of wood in there to mock up the height of a riser so you can see how it is going to fit. You will be able to see how far you can go before the cables need to be replaced. As mentioned, 2-3" is almost always ok without modifications, if you go higher, you will have to extend the brake line and throttle cable/oil line, and extend the wires to all the controls. I soldered the ends and used shrink tubing to seal them. there are a bunch of wires for the ignition kill switch, grip warmers, brake switch, and headlight switch to lengthen if you go too far.
It will depend on how you want to ride, if you do a lot of standing up, you may want to go at least 5". I hate bending over! It's harder on the back, especially for us old farts
04-21-2011, 11:54 AM
1979arctic
yeah i do a lot standing up and it kills my back!!!!!!
04-21-2011, 12:48 PM
My 99 rmk has always had a 3" riser and lately it has developed an unnerving flex in the hoop that I need to diagnose this off season.Enough to be obviously visible with noticeable movement of the console.I think long term durability should also be considered and of course how hard you ride your sled is an important factor.However,this machine has been ridden very hard.I can only imagine how much worse it would be if I had an extra 3 or 6 inches of fulcrum.
99 700 RMK
99 700 XC
05 900 RMK 166
02-13-2012, 01:07 PM
Gonna poke some new life into this thread. I am 6'4, have a 94 xlt and would like to find a riser. Im leaning towards 3" as to not have the extend the wiring/cables and I mostly sit when I ride so it is more for not hitting my knees while leaning/turning.
I guess I dont know what the difference between a riser and bar riser?
What are the thoughts about changing the handlebars too?
02-19-2012, 08:12 PM
Just yesterday I broke my steering columb right on the very top plate(not a problem since I am a welder). I also thought about putting a piece of roundstock down my columb till the bend in it just to for a little more strength. My sled only has a 2" riser I find it pretty good for myself, I am only 5'9".
03-09-2012, 08:32 PM
im 6' 3" right now but im only 16 so i might still get taller and i have the stock four inch risers on my firecat and i want to ge bigger ones. im looking for some suggestions should i go with 6 or 8 inch risers. i like to sit down because i trail ride but i stand up about 25 to 40 percent of the time. being as tall as i am when i stand it is not a good feeling on my back to slotch over like that. any imput would be nice. i do understand i will need to extend cables
sleds
mine:03 arctic cat firecat 500
dads:05 arctic cat pantera 600
moms:00 arctic cat zr 600
sisters: 98 arctic cat zl 440
01-29-2013, 02:27 PM
#19 (permalink)
Hey
I'm 5'11" and I have a 94-96 600 polaris xlt and I would like to put a handlebar riser on it. I would like to put a 6" on my sled tell me what u guys think. thanks
01-29-2013, 03:07 PM
#20 (permalink)
Live to ride
I'm 5'10" and I find that a 3.5" pivot riser is ok for standing, and I didn't have to buy any cable extensions.
The main thing is that you get a pivot style, so they go straight up, instead of angling back some.
'99 Polaris xc 500
'91 Arctic Cat prowler 440
