how to set up for deep powder - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 13 (permalink) Old 01-09-2010, 09:53 PM Thread Starter
just mEEEEE
Gunther47's Avatar
i have an MxZ 600 short track and was wondering what i can adjust to make it perform in deep powder
2000 MXZ 600
2003 Grand Touring 380f
89 Safari 377
Gunther47 is offline
post #2 of 13 (permalink) Old 01-09-2010, 10:10 PM
Ultrafrozen's Avatar
Set all rear skid springs to max preload to keep the track deep in the snow. Let out the limiter strap.
Ultrafrozen is offline
post #3 of 13 (permalink) Old 01-09-2010, 10:17 PM Thread Starter
just mEEEEE
Gunther47's Avatar
thanx that sounds like the formula for wheelies as well. im just getting more deep powder than normal
2000 MXZ 600
89 Safari 377
post #4 of 13 (permalink) Old 01-10-2010, 09:10 AM
Snowdoos Rider
MaineMXZ700's Avatar
do you have a good paddle trac on it ?
00 MXZ 700
02 formula delux 600
96 MXZ 440
MaineMXZ700 is offline
post #5 of 13 (permalink) Old 01-10-2010, 08:18 PM
Move the suspension mounts to the lowest possible holes in the tunnel.
This will give more depth to the track and improve the attack angle at the front of the track which will help the sled to "get on top" of the snow.
post #6 of 13 (permalink) Old 01-10-2010, 08:59 PM Thread Starter
just mEEEEE
Gunther47's Avatar
thanks, i will do all the above and my track is shot, just waiting on new slides so i can install the track that sits in the garage
2000 MXZ 600
89 Safari 377
post #7 of 13 (permalink) Old 01-12-2010, 04:06 PM
2008 polaris fst
increase the front spring pressure and replace hyfax!! raise up everything !!!
polaris 700xcsp is offline
post #8 of 13 (permalink) Old 01-12-2010, 04:58 PM
Mountain M0DERAT0R
PolarisINDY500's Avatar
to tell you the truth, what was said above is ok...but in actuallity, nothing you can do will really help prepare you for deep snow if your sporting a short track.
going from a 121 to a 162 (myself), ive noticed track length in conjunction with lug height is what you need to focus on.
as you said above, if your track is shot, id get rail extensions and a longer track with taller lugs. this will help move the snow a lot better and help with your flotation. track speed is essentially your life saver to get up and out of the deep snow.
2010 Arctic Cat M8 SP 162 (Jan '10 SOTM; '09-'10 SOTY)
MBRP Can, Polished Pipe, Powder Coated Tunnel & Bulkhead, M.A. Track Rack, XXXModRods Vents, AMP Gage Cage, Ice Scratchers, IceAge Rails, Shift Assist, Glide Washers, Rock Rollers, Frogzskin, BDX Anti-Slop & Anti-Stab, Air Can 2's, 44/36p helix, White SLP Powder Pros
The Original Logo ->
Originally Posted by Ultrafrozen View Post
This guy has been on this forum so long there is moss growing on his username!!!
PolarisINDY500 is offline
post #9 of 13 (permalink) Old 01-12-2010, 06:07 PM
True that, but notice that he is in NY, sure some areas get a lot of snow. but not like you are experiencing there.
You would be surprised at how well mine performs in deep snow.
Steep attack angle, 1" lugs, track set down for penetration, clutched to engage at 3400, and geared for a top speed of 90 now. It will "get up on plane" very easily and does not trench on hard take off/acceleration.
post #10 of 13 (permalink) Old 01-18-2010, 09:33 PM
sp600xltpolaris's Avatar
trust him
sp600xltpolaris is offline
post #11 of 13 (permalink) Old 02-13-2010, 10:26 AM
You can also re gear, I have a 137 Renny XP 800 and in deep snow I drop top gear from the 25 tooth to a 23 tooth for more grunt and switch to 1.75 track, I have had this machine in 8 foot of powder in Idaho and now 4 feet back here in Pa and for what it is it works amazing, our buds in Idaho can't believe how well it climbs,(it is pretty light too though) don't get me wrong it doesn't high mark as far as their 163 M1000's but then again they are a bit long to work the trees as well as mine and when it comes any type of trail or non climbing riding they can't touch me. as for suspenion, i stiffen the springs, but the limit strap seems to be prefernce and might be machine dependent, I actually tighten mine a hole or 2, this decreases the attack angle to help get you up on the snow. I also toss off the 5.7 skis for a set of 7" powder hounds, big improvement on the down hill keeping the front end up on snow.
Pzilly is offline
post #12 of 13 (permalink) Old 02-16-2010, 10:56 PM
Jake432's Avatar
Thats good info ^
Jake432 is offline
post #13 of 13 (permalink) Old 03-23-2010, 03:02 PM
Make sure you use high-temp silicone to seal around the hole where the exhaust pipe exits the sled. If exhaust gasses can leak back under the hood it will bog when the hood is covered in snow. Keep air intake clear of snow regularly and immediately if it bogs.
Short track will never work well in deep snow but you can have fun trying!
DeepDryPow is offline
