Old 01-14-2009, 11:44 PM   #1 (permalink)
Gmiller
Gmiller's Avatar
Rear Axle kit
Hey all
I have a 151x15x2 track on my 98 RMK, i was wondering what the advantages are of an inside axle kit? Right now i have 8in rear wheels. 2 outside one offset inside the rails, i heard an inside kit helps with side hilling which i could use considering where i live and ride. Any and all comments about the subject are grealty appricated! SLP has an inside axle kit for my snowmobile for 70dollars, i would also get lighter weight wheels considering mine are the plastic solid ones!
Thanks
Grant Miller
2005 Polaris 900 RMK 166 track, SLP can, Holtz Spindles and front A-arms. Inside Axle kit and 9in wheels, Compfusion motor mounts. All Factory Updates______
1998 Polaris 700 RMK, Twin SLP pipes and lightweight can, Exhaust temp guage, 151x2 track, fox shocks around and a big wheel kit.
Gmiller is offline   Reply With Quote
Old 01-17-2009, 11:41 PM   #2 (permalink)
High Mark
High Mark's Avatar
It allows you to turn quicker and maneuver easier with less rolling resistance. I changed mine and love the difference on my 162" King Cat.
High Mark is offline   Reply With Quote
Old 01-18-2009, 12:01 AM   #3 (permalink)
BC_Dan
My 2008 600 came stock with the inside axles, it's easier to move and lean than my 2006 with the wheels on the outside. Only thing, if you lose a bearing, you are done, there's no backup... so keep the bearings maintained!
Old 01-18-2009, 05:44 AM   #4 (permalink)
powderhound
The Nowledgable Yooper!
powderhound's Avatar
How would a kit like that help on a trail sled?
08/09 Miles-1015
ΑΣΦ-Alpha Sigma Phi
2009 Jan. S.O.T.M Winner!!!
CAN IT!If you have a can on your sled keep it OFF the trails
2008 RevXP 800r, 2006 Mach Z 1000, 2006 Rev 500ss Assault, 2004 MXZ 380f, 97 Touring LE 440, 96 Indy Lite 340, Tundra
powderhound is offline   Reply With Quote
Old 01-18-2009, 12:10 PM   #5 (permalink)
BC_Dan
I doubt you will find any performance increases with the wheels inside the rails on a trail sled, in fact, it may not be as good as the wheels on the outside of the rails. The bigger wheels will help with any track, the rolling resistance as the track goes around the wheels is less with a bigger radius wheel.. that will increase track speed on a trail sled as well.
Old 01-18-2009, 12:16 PM   #6 (permalink)
powderhound
so if i were to buy an 8inch wheel kit for my sled would i have to change the rear suspension and adjust the track or would they could slide on where the stock ones sit?
08/09 Miles-1015
ΑΣΦ-Alpha Sigma Phi
Old 01-18-2009, 01:47 PM   #7 (permalink)
No, you would need the offset axle though.
