Go Back   Snowmobile Forum: Your #1 Snowmobile Forum > Snowmobile Tech / Mod Center > Install and Product reviews
Old 09-02-2009, 07:18 PM   #1 (permalink)
SkiDoo86
Camoplast A/T plastic ski's
The latest and greatest added to my beloved snowmobile, is a complete set of Camoplast All Terrain Plastic Ski's. I opted to these for a couple of reasons. One being there made here in the GREAT state of Michigan. So why not boost the local economy? And I got a killer deal thanks to a local shop. These ski's are not your typical ski. They are the ONLY blow molded ski. SO enough said, here is my review....
This is what comes in the box...
The Skis, are an extrodinarily wide to give you the extra lift when your in the powder, and the carbides I went with are Woodys 6 inch Trail Blazers.
Here is a view of the old steel ski, along with the new camoplast. Top View.
The Bottom View.
You can see the bottom of the ski has a huge difference. Its almost like a tri-hull boat bottom. The theory is interesting, we shall see if it works later in the season.
Installation was a snap. All the hardware was included, which came with metal mounting brakets, new bolts, and bushings, an spacers. Also was included brand new rubber pads to keep the skis from tipping. See below.
Once the brackets were installed and along with the new Woody Carbides, it was a matter of 30 mins to shimmy the new skis on. Everything seemed to line up great. And the finish fit was near perfect.
The average cost of these skis is in the ball park of $220, with carbides. Depending on what you want it could cost more or less. They make a trail only ski, which is significantly narrower. THe original steel ski and carbide came in around 15 lbs per ski. The new plastic ski came in around 5 lbs per ski. That is a rough measurement, but do the math, thats 20 lbs less!!!
Visit the website at Camoplast
And like I said, its a local business in Coldwater, Michigan.
SkiDoo86 is offline   Reply With Quote
Old 09-03-2009, 07:33 AM   #2 (permalink)
Wow! Those are cool as hell!
Old 09-03-2009, 07:48 AM   #3 (permalink)
What was the price on those?
Old 09-03-2009, 03:57 PM   #4 (permalink)
SkiDoo86
Ebay has them listed for $220 with 4 inch carbides, and I think the hardware is included in that price. I upgraded and had Woodys 6 inch Carbides thrown in. It came to about $220 also, but the dealer also owed me big time, I think with all the hardware and the carbides I had it was originally $270.
The all terrain ski cost more, about 20 dollars more. Than the trail only ski.
Thanks for the input. I think this forum topic can really help us ALL!!!
Old 09-30-2009, 12:12 AM   #5 (permalink)
Waters88
Waters88's Avatar
I have had both styles, the normal width, and the extra wide skis on my sled. The skinnier ones I found were alot more aggresive, while the wider ones were not as aggresive. The downfall of the wide ones is that I found that they seemed to float TOO much going through corners, and the front end would get a little squirrley. I was able to get that taken out with more carbide.
Overall, I found that both styles are AWESOME, and I would recommed them to anybody.
Waters88 is offline   Reply With Quote
Old 09-30-2009, 08:36 AM   #6 (permalink)
Stagesrt4
sofa king
Stagesrt4's Avatar
and they designed the nose of ski to have a handle of sorts...
nice skis
Stagesrt4 is offline   Reply With Quote
Old 09-30-2009, 08:49 PM   #7 (permalink)
SkiDoo86
Yeah Im hoping they work well. Im gonna be makin some runs up to the UP, and I like the powder. So Im hoping they help. Im a 50/50 person, so I dontthink I could of gone wrong.
Once I try them Ill finish the review.
Old 11-16-2009, 09:14 PM   #8 (permalink)
jonathan kaus
skidoo 96
ski skins
What do the plastic ski skins do. would it be better to buy the plastic ski or the skin for my sled
jonathan kaus is offline   Reply With Quote
Old 11-16-2009, 09:57 PM   #9 (permalink)
SkiDoo86
Do what ever fits your budget. Ski skins will eliminate friction anf help your sled move easier. And they will add very minimum flotation.
Plastic skis, eliminate friction, eliminate massive amounts of weight, look better, and perform better.
But again, do what fits your budget. Camoplast is the cheapest of the plastic skis out there I believe right now, you can spend anywhere from $200 to up to $800 dollars per pair.
Old 11-17-2009, 09:44 AM   #10 (permalink)
Waters88
Waters88's Avatar
In Canada the camoplast skis with install kit and with carbides will run you about 325-350 tax.....
OFSC Trail Patrol Member
1998 Yamaha Vmax 600- 20,000KMs and still tickin'
2002 Yamaha Viper- Sled-4000KMs, Motor- 2400KMs
1973 Polaris Colt 340
1996 Ski-Doo Formula 670- Broken all the time
1999 Yamaha Wolverine 350-Quad
Old 11-18-2009, 09:02 PM   #11 (permalink)
jonathan kaus
skidoo 96
k thanks guys
