Carburetor leaking fuel out of both over flow hoses - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-29-2012, 11:58 AM   #1 (permalink)
mxz700brp's Avatar
Cleaned carbs yesterday and put them back together. the sled ran perfect but I smelled gas and just thought it may have been left over from when I took them off and dump them out. rode it for 1 hour and realized I used half a tank of fuel so I looked into it today and as soon as I started it the 1 carburetor was leaking out of both overflow hoses....stuck float, blockage somewhere, choke cable not seated right? can someone offer some advice for a quick fix?
mxz700brp is offline   Reply With Quote
Old 12-29-2012, 02:12 PM   #2 (permalink)
wastedincome's Avatar
I would lean toward stuck or float or bad float Be sure no fluid is in floats If so they have hole and bad. Depending on carb style there should be a clip that holds the needle jet to the float. Best of luck I'm sure others will chime in soon
02' XCSP 600 EDGE-X with M-10
wastedincome is offline   Reply With Quote
Old 12-29-2012, 03:34 PM   #3 (permalink)
Stuck float or debris in the inlet needle/seat. Bad floats are pretty rare, they happen, but not often. Did the float get put back in correctly?
Old 12-29-2012, 04:08 PM   #4 (permalink)
mxz700brp's Avatar
I opened it back up and sprayed carb cleaner thru out the entire thing and finished it off with a can of air duster just to be certain there was nothing stuck in there. It worked, no more overflow. I also learned that the spring & plunger on the end of choke cable comes of very easy. They both fell off under the motor taking me over and hour to find them..lol...thanks guys.
Old 12-29-2012, 04:14 PM   #5 (permalink)
That dang belly pan is always the culprit to my missing anything. It's amazing how everything that goes there just disappears.
1on3off is offline   Reply With Quote
Old 12-29-2012, 06:18 PM   #6 (permalink)
plus, the plunger is brass so you can't snatch it with a magnet. I never did find one that went to one of the carbs on my 650
Old 12-29-2012, 11:37 PM   #7 (permalink)
nunrleft's Avatar
I had the same thing happen to me a couple weeks ago. I hadn't tightened the needle and seat on one of the carbs.
nunrleft is offline   Reply With Quote
