Bombardier Muskeg info needed - Page 2 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-23-2012, 05:43 PM   #21 (permalink)
Looks good. I also have 2 spare complete tracks and many other spare parts stripped from the 2nd unit that was part of the deal.
I did oil and filter today plus a lot of lubrication. Gotta get a carb kit. The accelerator pump squirts nothing. Probably dried out. Carter 1 bbls are childsplay,so no big deal.
PS the fan pushes air OUT of the engine compartment,through the radiator. It make sense,as it is a low speed vehicle and the engine IS in the cab with you!
Hammermechanic is offline   Reply With Quote
Old 12-23-2012, 06:11 PM   #22 (permalink)
That is awesome!
And with a points/condenser system, you don't have to worry about the EMP
Old 12-24-2012, 05:01 AM   #23 (permalink)
Now all you need is a drag and you are ready to go grooming!
Old 12-24-2012, 06:40 AM   #24 (permalink)
AWESOME project! A friend had one of those, although in much worse condition. Ended up selling it. How wide is it? A lot of plows nowadays are electric with their own hydraulics built onto the plow unit.
1999 Ski Doo Grand Touring
Old 12-24-2012, 08:36 AM   #25 (permalink)
Thanks to all for the positive replies! It is 12' Long, 7' High, and 7'3" Wide at it's widest point. The tracks have an appx 7' wide footprint. A 7-8' plow would do nicely.
Old 02-07-2013, 07:04 PM   #26 (permalink)
Update
Much work has been done since my last post. I was actually searching for more info and found a link to THIS THREAD,so here I am again.
Re worked the winch and PTO system. Power in and out as well as freespool all works as it should now.
Replaced several tires w/good used ones from the parts unit.
Replaced MANY grease fittings w/new ones as many either wouldn't take grease or the tips were so worn away that the grease gun wouldn't stay put on the fitting as they should.
Installed new fuel tank,complete w/new sending unit and a Stewart Warner Fuel level gauge.
Had to solder a tiny crack in the brass float inside the carb.Let it sit for a few days and the float would fill with fuel,keeping the needle away from it's seat,thus flooding the engine. Rebuild kit does not include a new float,and I cannot seem to source one anywhere,so I repaired it.
Still haven't had it out for a ride. I have moved it a few times.All seems to work as it should.
Currently have both doors off and apart to sandblast and repair,outdoors,on a fairweather day soon.
Thanks for all the interest and info. Good people here!
Old 02-08-2013, 09:37 AM   #27 (permalink)
Sounds like a cool project, keep us updated!!
96Polarisxlt is offline   Reply With Quote
