stroker - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-02-2012, 03:16 PM   #1 (permalink)
stroker
what will happen if i take 800 xc connecting rods and use them with a 700 top end? the stroke on the 700 is 68mm,the 800 70mm. i know it will increase compression and lessen clearences to the head.but can it be done and will i have to change anything else? i bought a used lower end and was told it was a 700 ends up its a 800! WTF!..
blueweld is offline   Reply With Quote
Old 12-02-2012, 11:46 PM   #2 (permalink)
You would have to machine a plate to go between the cylinder and the crank case to make up for the longer stroke. "stroker plate"
Old 12-03-2012, 06:05 AM   #3 (permalink)
You can contact Cometic the gasket company and they can make you the right thickness gasket and or a shim plate! BUT your piston will travel TOO far down! The correct way to do it is to split the difference! Which means a different head too!
