seat removal - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-25-2012, 08:40 AM   #1 (permalink)
DanM675's Avatar
seat removal
Hi i'm trying to remove a seat from a 1996 skidoo formula ss 670. I tried to remove the two bolts in the back but once they were loose they just spun. Any ideas
DanM675 is offline   Reply With Quote
Old 11-25-2012, 09:25 AM   #2 (permalink)
Grudman
Grudman's Avatar
Look under neath the sled above the track see if you can see the bolts. If so you going to have to try and and get a vise grips on them or a flat head screw driver to get the bolt to stop turning so you can get the nutt off all the way. Most time you just have to push up on the bolt tight to the tunnel so it doesnt spin depending if it damage or not.
Grudman
Old 11-25-2012, 11:20 AM   #3 (permalink)
DanM675's Avatar
It looks like the T bolt is sitting just inside of the seat on top of the frame and just goes through the hole to where you can see it underneath the sled above the track. So are you saying that there is a metal piece inside of the seat, that if you push up on the T bolt that it will hold it in place so you can get the nut off?
Old 11-25-2012, 11:58 AM   #4 (permalink)
TRH- Troll Raising Hell
JheLrey's Avatar
Is there a storage compartment on the seat? Usually that is where the bolt heads are hid
Snow: The other white drug!
Old 11-25-2012, 01:07 PM   #5 (permalink)
DanM675's Avatar
Yes there is a storage compartment on the seat. But it looks like the two bolt our in front of that.
Old 11-25-2012, 02:43 PM   #6 (permalink)
Grudman
Grudman's Avatar
1996.jpg photo by ckoum | Photobucket
Ok I found a drawing of your sled take a look!
Grudman
Old 11-25-2012, 04:37 PM   #7 (permalink)
DanM675's Avatar
Thanks for the drawing Grudman.Yeah you can find drawings of every model and year of skidoo right here.
http://parts.ski-doo.com/Index.aspx?..._id=0&siteid=1
Old 11-25-2012, 06:41 PM   #8 (permalink)
A lort of the time, those bolts are spot welded to a plate inside the seat and the welds break and they just spin.
1999 Ski Doo Grand Touring
Old 11-26-2012, 09:16 AM   #9 (permalink)
DanM675's Avatar
Oh thanks that would explain a lot.
