anyone ever tried to tig a cylinder - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-13-2012, 07:15 PM   #1 (permalink)
Roof_991's Avatar
so I had to drill and retap the holes for the carb boots to mount to. I got 10 of the twelve done with no problem I started the 11 got the tap about halfway and all the sudden the ear the bolt goes though broke off. when I drilled it I made sire to center it just drilling out the old bolt. while tapping this hole there was no struggle I didnt have to force anything just all of the suddem it popped of. so my ? is has anyone ever tried to tig weld a cylinder. I was goint to try and tig the ear back on but just figured id ask if anyones ever tried to tig on a cylinder and what the outcome was
Sent from my SCH-I500 using Snowmobile.com App
Roof_991 is offline   Reply With Quote
Old 11-13-2012, 07:23 PM   #2 (permalink)
77zman's Avatar
Yeah we do it to the old kolher motors not hard to do if ur good at weld aluminum
My ZR is faster then your ZR
77zman is offline   Reply With Quote
Old 11-13-2012, 07:33 PM   #3 (permalink)
TRH- Troll Raising Hell
JheLrey's Avatar
I would put all of the other bolts in and tighten them up. Drill out the hole, fill with JB Weld, shove bolt in, call it a day. It should be air tight is what you are after. Let's face it, it just holds the carbs on. It's not a motor mount bolt
Snow: The other white drug!
Old 11-13-2012, 07:39 PM   #4 (permalink)
Roof_991's Avatar
it broke half the ear off so theres only half a hole thats why I was asking if I was to tig that piece back on if I would work, I have an 01 mxz 800 I just wanted to see if its been done to know if you could even tig on these cylinders
Old 11-13-2012, 09:17 PM   #5 (permalink)
JheLrey's Avatar
JB Weld the piece on! Drill out and tap
Old 11-14-2012, 06:35 AM   #6 (permalink)
Bring it down I have a guy here that does it all the time! What were you thinking? drilling it out!
Ok if you break off a bolt, STOP, don't drill! Take a flat washer and just weld it to the broken bolt! The heat of the weld will go down threw the bolt and expand it! Let it cool awhile and then just spin the broke bolt right out with a pair of pliers! REALLY!
Old 11-14-2012, 07:42 AM   #7 (permalink)
Roof_991's Avatar
Ok if you break off a bolt, STOP, don't drill! Take a flat washer and just weld it to the broken bolt! The heat of the weld will go down threw the bolt and expand it! Let it cool ahile and then just spin the broke bolt right out with a pair of pliers! REALLY!
I can do it at work I just wanted to make sure it was weldeble. and I tried the flat washer trick with no luck
Old 11-14-2012, 09:06 AM   #8 (permalink)
Roof_991's Avatar
does anyone know if these cylinders have any magnesium in them
Old 11-14-2012, 10:13 AM   #9 (permalink)
I believe if they did it would say Magn somewhere on it?
If the washer trick didn't work the weld didn't penetrate deep enough! And don't use a nut! for some reason it pulls the heat up instead of letting it go down the bolt?
Old 11-14-2012, 11:04 AM   #10 (permalink)
Roof_991's Avatar
I had my welder cranked up after I tacked the washer on it was glowing red even the bolt
Old 11-14-2012, 12:25 PM   #11 (permalink)
weld a washer on first let it cool then weld a nut onto the washer, you get best of both worlds heat from washer and grip to take it out from bolt.
squiggs650 is offline   Reply With Quote
Old 11-14-2012, 01:47 PM   #12 (permalink)
It can be welded with no problem. It can get a little tricky because cast aluminum has a lot of porosity. Should be fine though considering it doesn't have to be sealed. Clean it REAL GOOD. Oil and residue over the years seeps into the pores of the casting and can make welding it a pain. Should be fine though.
Old 11-14-2012, 06:52 PM   #13 (permalink)
77zman's Avatar
Have you tried a bolt extractor yet. And plz dont jb weld it if it does break go get it fixed the right way other wise you'll be fixing over and over. Like i said we have been welding on cylinders for years with no problems at all. DO IT RIGHT THE FIRST TIME!!!
Old 11-14-2012, 07:23 PM   #14 (permalink)
Roof_991's Avatar
the ear broke off the bolt is out so im taking it to work gna try and tig it 2morrow hoping theres no magnesium in it because if there is and I try to tig it at work it will blow apart
Old 11-14-2012, 07:46 PM   #15 (permalink)
77zman's Avatar
. Or those cylinders paint? If not you would be easily able to notices the oxidation on those cylinders. Magnesium oxides at a very fast rate. And ive never heard of magnesium cylinders before.
Old 11-14-2012, 07:49 PM   #16 (permalink)
Roof_991's Avatar
no not painted but not all aluminum is pure aluminum I was talking like an alumi.um alloy where its a mixture
Old 11-14-2012, 10:12 PM   #17 (permalink)
77zman's Avatar
Yeah i dont think ur going to have a prob. Just make sure the area is super clean of any oils or impurities and you shouldnt have any problems
Old 11-14-2012, 10:31 PM   #18 (permalink)
Roof_991's Avatar
ya I cleaned it up took a grinder to it and put a decent groove in it so I get good penitration ill let yall know what the outcome is
Old 11-15-2012, 02:53 AM   #19 (permalink)
Pics would be nice!
Old 11-15-2012, 04:25 PM   #20 (permalink)
Roof_991's Avatar
well I got it tigged back together had to build it up a little bit so I have to buff it and retap it.
