Need a little help here PLEASE - Snowmobile Forum: Your #1 Snowmobile Forum
Old 10-23-2012, 11:37 PM   #1 (permalink)
Lightbulb Need a little help here PLEASE
hello i am chad lol i just got a 1992 rxl 650 and im having problems getting it started i have a 1992 efi 500 has done me great for over 10 years i just wanted some thing different so i bought this for 175 dollars i need some advice it will fire but not start ok here the thing if i pull the plugs and pull the heck out of it then it will almost start for about ten seconds then dies im looking for any advice at all thanks i really look forward to advice
chad_ewing is offline   Reply With Quote
Old 10-23-2012, 11:57 PM   #2 (permalink)
aduck's Avatar
Go through the carbs real good.sounds like its flooding.
93 mach1 670
02 rmk 800 162
95 powder special 580
Old 10-24-2012, 08:29 AM   #3 (permalink)
RXL is an EFI.
Old 10-24-2012, 08:19 PM   #4 (permalink)
And be carefull with the EFI!
Old 10-24-2012, 11:11 PM   #5 (permalink)
aduck's Avatar
Ha ha nice catch!
93 mach1 670
02 rmk 800 162
Old 10-25-2012, 12:44 PM   #6 (permalink)
SD Rider
Check the EFI box for any codes flashing. There will be a little red LED just in front of where the wiring harness connects to the box. Turn the key to the ON position and pull it a couple times, then check. It will be a dot/dash code, like one long "dash" and three "dots" would be 13. Go to polarisfiles.com and search for EFI codes and you should be able to find a chart with each code and what they mean. That's where I'd start, anyway. Also, the battery has to be running at 100% or these things WILL NOT run correctly. Don't waste money on those $80-100 batteries because they still don't last more than a season. I ran a $40 Super Crank brand battery in my '91 and never had an issue. Plan on buying a new battery each year.
1974 Arctic Cat Cheetah 340
Gonna be set up for ice fishing. Should be good for it's purpose!
Most snowmobile problems are caused by a loose nut connecting the handlebars to the seat.
jordandakota is offline   Reply With Quote
Old 10-27-2012, 09:44 PM   #7 (permalink)
One problem down one to go?
so i bought it and knew there was a problem so i cleaned the air bow got new plugs and a new fuel filter no changes so i went and bought an el cheapo compression tester #3 only had 28 pounds of compression the other 2 had 100 pounds so problem solved pulled down the engine and the rings were welded to the piston so one more question if i hone out that cylinder will i have to buy over sized pistons for it or can i run std size in it?
Old 10-27-2012, 11:25 PM   #8 (permalink)
SD Rider
Honing shouldn't increase the cylinder diameter. If it does, you went a little overboard. As long as the cylinder walls are scoring-free, honing and standard pistons/rings should be just fine. Check them carefully. Even a small scratch in the walls might not come out with a honing, in which case it would need to be bored out a bit. You'll like the power out of that 650. My '91 was awesome. There's nothing better than hearing that triple start to scream when you hit the power at about 5700 rpm.
Old 10-28-2012, 05:13 AM   #9 (permalink)
As long as the scratch is not too deep [as in it can catch your fingernail] then a honing will help by removing the glazing and allowing a better seal between the rings and wall.
If it can catch your nail, you can send it out to be replated for less than over boring it.
but, in either case you would also need to send the piston that you will be using along with it.
Old 11-26-2012, 05:41 PM   #10 (permalink)
here is one more question how would i put a 151 on a 1992 rxl 650 little input would be nice
Old 11-26-2012, 08:19 PM   #11 (permalink)
smokingcrater's Avatar
a 151 track? Why? yes, it could be done with a proper replacement skid from a totaled 151, but why?
3) 2004 Yamaha Warrior
4) 2006 Yamaha Nytro
Old 11-26-2012, 08:30 PM   #12 (permalink)
Midnight Polaris
XCRacer440's Avatar
Is anyone 100% certain these cyls from this old 650 are Nacasil (Sp)?
XCRacer440 is offline   Reply With Quote
Old 11-27-2012, 04:48 AM   #13 (permalink)
scrammy650's Avatar
not shure my 95 rxl had reg. sleeves
scrammy650 is offline   Reply With Quote
Old 11-27-2012, 06:33 AM   #14 (permalink)
The 92 RXL is Cast iron!
