exhaust - Snowmobile Forum: Your #1 Snowmobile Forum
Old 08-16-2012, 09:49 PM   #1 (permalink)
dhridenh's Avatar
exhaust
ok so i know i should ride my sled be for i ditch the original exhaust but i want somthing new mine is rusting and leaks a little bit anyone have a used aftermarket exhaust not like the stock like a dg or stinger or can i cut it and have it welded up to make like my own caned exhaust thoughts
Old 08-17-2012, 06:36 AM   #2 (permalink)
First whick sled? As for rust and leaks, high temp silicone and new springs help alot. And rust is gona happen unless you paint it every off season!
And if you just want to change the sound I have a fix for that as well as performance too!
Old 08-17-2012, 02:04 PM   #3 (permalink)
dhridenh's Avatar
oo really its the efi sks and i want more sound and power from it
i have seen the stingers witch i dont really like and the dgs witch look alright but i might just go with a stinger i saw a dual exhaust that some one had but i cant remember were and who made it
Old 08-17-2012, 02:58 PM   #4 (permalink)
ridgerunner's Avatar
dg and aaen both made pipes for your sled and you can find them forsale used if you look. the problem is your sled is efi. you would have to swap to carb or find someone that can fix your ecu to work with the pipe. and it is getting hard to find things like that for a sled that is older.
No sledding this season.... sold them both to pay for a wedding.
ridgerunner is offline   Reply With Quote
Old 08-17-2012, 03:26 PM   #5 (permalink)
dhridenh's Avatar
i would expect the efi would ajust to more air flow like in a car the brain should tell it it needs more fuel and air
Old 08-17-2012, 04:28 PM   #6 (permalink)
If you change the pipes, you will need to have the ECU reflashed or use a controller such as Boondocker.
Old 08-17-2012, 04:47 PM   #7 (permalink)
dhridenh's Avatar
i cant seem to find any controlers for the efi and i have no idea were to go to have it reflashed
Old 08-17-2012, 04:53 PM   #8 (permalink)
dhridenh's Avatar
even with a dg pipe i would have to do it as well i guess
Old 08-17-2012, 07:07 PM   #9 (permalink)
yeap.... any pipe change will require you to have the ecu setup to work with it. and you have a one piece pipe so you can't change the can either so you are kinda stuck. on the otherside, even with adding the pipe it doesn't make a huge amount of power over stock. plus if you do try and find a pipe, go with an aaen not dg, dg didn't make much more power on the old iron than stock, just more noise.
Old 08-17-2012, 07:33 PM   #10 (permalink)
dhridenh's Avatar
hmmm alright guess no pipe for this guy
Old 08-18-2012, 07:07 AM   #11 (permalink)
Well that sled is exactly why Pollaris gave up on EFI! You can still work on your exhaust. I make up an adjustable fuel presure regulator for the Cat! Might be able to adapt to your sled? And then a simple well placed hole drilled into your can!
