503 fan !!!!! HELPP!!!!!! - Snowmobile Forum: Your #1 Snowmobile Forum
Old 08-16-2012, 07:53 PM   #1 (permalink)
Ok so i have a 1997 skidoo mxz 440 fan with a 503 transplant. whoever did the the transplant did a pretty poor job with all the wiring and everything. when i got the sled the motor was leaking oil out of the PTO crank seal. once i tryed to replace that all i found was problems. all of the bearings in the lower end were gone. ( i think she was run dry of oil one to many times).. but anyways... i had the motor rebuilt and i installed it, took it on a 60 mile ride and it ran fine.. i got home and the lights dont work.. but they did on the ride.. i have no head light, no dash light, no tach, and no speedo... anyone have any ideas?
jtclark62789 is offline   Reply With Quote
Old 08-16-2012, 08:08 PM   #2 (permalink)
zdw0889's Avatar
Voltage regulater?? Had problem simalar to that on a old exciter
96 polaris ultra sp 680 dg can cobra windshield, 89 el tigre ext 530, 98 zr 600 efi, 80 yamaha exciter 440 l/c, 96 cougar 550.
zdw0889 is offline   Reply With Quote
Old 08-17-2012, 06:39 AM   #3 (permalink)
Double check all the connectors. Even take them apart and give them a shot of WD40.
Old 08-17-2012, 09:28 AM   #4 (permalink)
There is a relay underneath the handlebars that is responsible for the lights and the head lamps. Test and replace it.
Cfiondella is offline   Reply With Quote
Old 10-08-2012, 05:42 PM   #5 (permalink)
Where exactly? because the person i got it off from put a riser kit on it so everything is exposed.
Old 10-08-2012, 05:43 PM   #6 (permalink)
where is the voltage regulator?
Old 10-08-2012, 07:21 PM   #7 (permalink)
zdw0889's Avatar
Not a 100% sure but somewhere under the hood to the back by where your feet go.
Old 10-09-2012, 06:13 AM   #8 (permalink)
Some are on the right footrest, others are under the engine.
Old 12-24-2012, 07:00 AM   #9 (permalink)
would i have to move a bunch of stuff out of the way to see it on the right foot rest? because i cant see anything, and if it was under the motor what side? this is a real hack job and it is kinda pissin me off...
Old 12-24-2012, 07:23 AM   #10 (permalink)
If it's under the engine, it would be on the right side by the frame.
Old 12-24-2012, 03:18 PM   #11 (permalink)
ok so i changed out the voltage regulator.. that wasnt it.. anyone else have any ideas?
Old 12-24-2012, 03:45 PM   #12 (permalink)
Rczr600rider's Avatar
Does the tail light work? If so I would check the wiring harness going to the hood for a broken ground wire.
Old 12-24-2012, 03:56 PM   #13 (permalink)
No there is no lighting at all
Old 12-24-2012, 04:42 PM   #14 (permalink)
'93 Phazer and The Kid
Phaze's Avatar
Lighting coil? You'll need an ohm meter to check the resistance. Not sure the specs or which two wires to hook up to, someone will know........
'05 Yamaha RX1 ER 1000
'93 Yamaha Phazer II LE 485
2012/2013 miles: 484 WooHoo!!
2011/2012 miles: 737
Old 12-24-2012, 06:47 PM   #15 (permalink)
Yellow wires are the lights.
Old 12-24-2012, 06:55 PM   #16 (permalink)
Where is the lighting coil? And would that have anything to do with the tach and the speedo not working?
Old 12-24-2012, 08:13 PM   #17 (permalink)
The lighting coil is part of the stator. It provides power for all your accessories, not just lights.
