HELP! Anyone know anything about 4 wheelers - Snowmobile Forum: Your #1 Snowmobile Forum
Old 08-14-2012, 07:08 PM   #1 (permalink)
zdw0889's Avatar
Just got this 4 wheeler on a trade. Its a 96 honda 300 ex bored to a 350? And big bore carb kit. Guy i got it from said he could only get it to run for two min and plug would foul. He had the choke on. Anyways it runs but falls on its face when you punch it. But it will still get up just not nearly like it should. I know nothing about these machines. Need help please
96 polaris ultra sp 680 dg can cobra windshield, 89 el tigre ext 530, 98 zr 600 efi, 80 yamaha exciter 440 l/c, 96 cougar 550.
zdw0889 is offline   Reply With Quote
Old 08-15-2012, 03:53 AM   #2 (permalink)
Have you checked to see if the carb was clean?
1999 Ski Doo Grand Touring
Old 08-15-2012, 07:39 AM   #3 (permalink)
And if all the right jets are in the carb!
Old 08-15-2012, 07:30 PM   #4 (permalink)
zdw0889's Avatar
I'm getting the carb looked at tomorrow to make sure everythings ok and to get it tuned right. And see if that makes a difference. Its got low end power just not top end
Old 08-15-2012, 07:33 PM   #5 (permalink)
zdw0889's Avatar
And carb looked ok but then again i didnt take it off to inspect it
Old 08-16-2012, 03:55 AM   #6 (permalink)
It can look fine on the outside, but the inside can be trashed.
Old 08-16-2012, 07:05 AM   #7 (permalink)
Even if the inside looks good doesn't mean anything either! If it was rejeted who knows what is in it! Read the numbers on the main and pilot jets.
Old 08-16-2012, 07:23 PM   #8 (permalink)
zdw0889's Avatar
Took it out and cleaned very good. Jets were almost completely clogged. Put it back on. A lot more power!
Old 08-16-2012, 07:26 PM   #9 (permalink)
zdw0889's Avatar
Not 100% sure cause i dont have the jets in front of me but it was k420 or somethin like that.
Old 08-17-2012, 12:32 PM   #10 (permalink)
zdw0889's Avatar
So ran good for like 45 min the all the sudden boom no power wont even stay running. So took off the carb jets were clogged. Cleaned them. Inspected the tank. WOW dirty. Had spots of rust in it. Cleaned it out best i could. Changed oil and oil filter put new plug in. Just need to go grab some gas and hope it lasts longer. I have a feeling i will have to repeat this a few times.
Old 08-18-2012, 07:10 AM   #11 (permalink)
I have a similar prob with a Kawi bike! You may need to get some Fuel Tank Coating?
Old 08-18-2012, 09:19 AM   #12 (permalink)
zdw0889's Avatar
Got a longer run time still running decent. But top end still seems a little sluggish til 3rd gear. Do you think the top end could need replaced? Tried to get a compression tester for it but it would have to be ordered and was expensive. So ill wait on that. Where do i get gas tank coating? Auto parts store?
Old 08-18-2012, 04:30 PM   #13 (permalink)
aduck's Avatar
Standard compression testet will work fine. Bout 25 bucks at any auto parts store
Sent from my M865 using Snowmobile.com App
93 mach1 670
02 rmk 800 162
95 powder special 580
Old 08-18-2012, 08:40 PM   #14 (permalink)
mr.deeds's Avatar
You can buy that tank coating at Rocky Mountain atvmc (i've seen their adds on this forum... and good prices) and Dennis Kirk would have it. I think its called Creme-- I used it on a rusty tank and it fixed the problem pretty good. You do want to have it as clean as possible before you do it. I would also put one of those little in-line fuel filters on- just to help a little more.
mr.deeds is offline   Reply With Quote
Old 08-18-2012, 09:12 PM   #15 (permalink)
zdw0889's Avatar
Aduck i have a standard tester wrong size wont fit. And yea when i cleaned the carb the second time i used a inline filter
Old 08-18-2012, 11:17 PM   #16 (permalink)
aduck's Avatar
Are you missing the other fittings. I use mine on my 400ex and 450 as well as the sleds no issues
93 mach1 670
02 rmk 800 162
Old 08-18-2012, 11:24 PM   #17 (permalink)
zdw0889's Avatar
Can i hold my compression tester on there with someone trying to start it and get a good reading. My tester only came with one extra fitting
Old 08-19-2012, 06:38 AM   #18 (permalink)
I think I still have the reducer fitting that came on one of my testers?
Old 08-19-2012, 10:42 AM   #19 (permalink)
another thing to consider is fuel tank venting as well as carb vents.
your issue almost sounds like the tank isnt properly venting and creating almost a vapor lock situation.
if your carb is equipped with a vent line on the upper portion, same issue can occur if this line is plugged.
Old 08-19-2012, 12:45 PM   #20 (permalink)
zdw0889's Avatar
The gas tank vent is just the hose coming off the cap right? If so i replaced that cause there wasnt one. Ill have to check out the carb next time i take it out for the vent lines. And kc dont wanna take your extra might need it some day ill buy one if i can find it.
