better fuel econmy - Snowmobile Forum: Your #1 Snowmobile Forum
Old 08-10-2012, 05:16 PM   #1 (permalink)
skidoo1357's Avatar
better fuel econmy
hey guys im just curious what i can do to my sled so that i can get better fuel econmy it is stock right now any tips?
skidoo1357 is offline   Reply With Quote
Old 08-10-2012, 06:29 PM   #2 (permalink)
There are several things that could be done. What sled?
Check that the track is only as tight as need be as not to ratchet.
The 8" idlers could help as well as extervert drivers.
Less friction with a taller carbide?
As lean as safe on the carbs.
Clean clutches that will shift out a bit quicker (may ecelerate slower)
I understand that the belt drive for the chain case has less friction?
Old 08-10-2012, 11:00 PM   #3 (permalink)
skidoo1357's Avatar
05 skidoo mxz Rev
Old 08-11-2012, 06:59 AM   #4 (permalink)
What motor? 600SDI?
Old 08-11-2012, 07:26 AM   #5 (permalink)
skidoo1357's Avatar
Opps 500ss
Old 08-11-2012, 08:09 AM   #6 (permalink)
Alex
600RacerX's Avatar
How much are you getting out of it.
I suspect that you probably won't get much more out of it. Main things are to loosen the track, and keep your thumb out of it's throat.
600RacerX is offline   Reply With Quote
Old 08-11-2012, 10:42 AM   #7 (permalink)
skidoo1357's Avatar
I honestly dont know i havnt even gotten a chance to burn through half a tank cuz of last years crummy winter here thought id check and see based on the rediclous gas prices
Old 08-11-2012, 05:22 PM   #8 (permalink)
Alex
600RacerX's Avatar
Well, the SS is pretty tapped out for fuel economy. You will find that is in fact quite acceptable in comparison to other sleds in the market. I believe people usually get around 15 mpg. Only way to do much better is to just buy the SDI or the newer ETEC engines.
Old 08-11-2012, 08:07 PM   #9 (permalink)
I doubt it would get 12 -13!
Old 08-12-2012, 08:24 AM   #10 (permalink)
Actually, even the 500SS will get up to 18mpg.
Old 08-12-2012, 10:02 AM   #11 (permalink)
Alex
600RacerX's Avatar
This aint no smelly Cat here KC. We're talking big boy engines.
Old 08-12-2012, 02:49 PM   #12 (permalink)
You mean you AINT talking big boy motors!
Isn't the 500ss actualy a 600?
Old 08-12-2012, 03:35 PM   #13 (permalink)
Alex
600RacerX's Avatar
Yes sir. 597 CC's
Old 08-12-2012, 06:25 PM   #14 (permalink)
dhridenh's Avatar
lol the 500 ss is a 600 i had no idea
Old 08-12-2012, 06:32 PM   #15 (permalink)
Yep top of the small bores!
Old 08-12-2012, 07:50 PM   #16 (permalink)
Alex
600RacerX's Avatar
Well, it depends on how you look at it. Seeing as the SS is 3 CC's bigger than skidoo's 600 block... It's hard to call it top of the small bores.
Old 08-12-2012, 08:34 PM   #17 (permalink)
I am refering to the 600 cc class! And for that mater the 700cc class may be soon falling in status????
Old 08-12-2012, 08:38 PM   #18 (permalink)
Alex
600RacerX's Avatar
Well the 600's are creeping closer and closer to the last 700's that were made.
I personally consider small bores the 440-550 class. But then again I own a 600, so that might be part of it.
Old 08-13-2012, 06:35 AM   #19 (permalink)
Well a 600 hasn't had that status since 95-6-7-8? Speaking of the past what was the largest displacement in 98? Cat didn't even make a 700 that year!
Old 08-13-2012, 07:29 AM   #20 (permalink)
skidoo1357's Avatar
I was told the ss was 580 its not?
