08-04-2012, 09:03 PM
1993 Polaris xlt 580
Chaincase oil substitutes
Hi! It is time to change the oil in my xlt chaincase. Are there any automotive oils that could substitute? Like 80-90 gear oil or something? Just curious as it is much cheaper and easier for me to get some sort of gear oil. Thanks!
08-04-2012, 10:01 PM
umm to be honest with u i only run pure from polaris or spectra chain case oil full synthetic oils the pure was recommended to me by the dealership and they said the spectra was a good substitute for the pure even tho u get more oil and the oil is cheaper with the pure polaris i like both the oil is very low viscosity so that u get good lubrication in the cold weather if u use 80-90 its ganna be thick in the cold weather i use a 75-90 in the rear end of my 6.0 gmc dif so
use the good stuff dont cheap out sleds are expensive to own and operate like the older ones
08-04-2012, 11:19 PM
If you're not going to use chaincase fluid, ATF is a close substitute. A lot of guys use it, I have in the past when I had a chaincase problem and the dealer wasn't open. It worked fine. Like dhridenh said, 80-90 gear fluid is really thick and more appropriate for gears. Your chaincase doesn't have gears, it has sprockets and a chain and needs a thinner oil that can penetrate into the chain links.
08-05-2012, 07:02 AM
I use syn 5W30 with syn Lucus oil additive! Works better than the OEM!
08-05-2012, 10:46 AM
see to me first off i am a mech and i work on cars i dont like the lucus additive and the 5w 30 full synthetic is still a little to thick especially with the oil additive but to each his own i guess i just recommend oem and i have herd of using atf so what ever u want to do
08-05-2012, 03:14 PM
In a chain case you should use a non-detergent single viscosity oil.
Multi-vis and detergents do not stick to the chain as well, it slings off too easily.
As single weight {SAE 30 max} is OK, but a 5 weight is sufficient.
08-05-2012, 03:52 PM
yea i can see how that would be ok i still would recommend full synthetic
08-05-2012, 05:57 PM
The Syn Lucus isn't very heavy and sticks perfectly!
08-05-2012, 06:19 PM
the stuffs like molasses lol i have used the stuff lol
08-05-2012, 07:42 PM
A quart of synthetic 30WT is about $8.
1999 Ski Doo Grand Touring
08-05-2012, 08:21 PM
i think i paid 8 for pure synthetic chain case oil at plastow power sports
08-05-2012, 09:30 PM
ride till your broke
i have to agree with trans fluid.
but everybody has there opinion.
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e-mint!!
08-06-2012, 06:34 AM
Amzoil makes a chain lube.
08-06-2012, 07:04 AM
really? have you ever used it?
current sleds
04 rev800ho gade
95 formulaIII 600
08-07-2012, 03:50 PM
Yeah!
