You do not want to use a CV belt drive system on a prop... CV's are meant for variable loads, a [fixed] prop is completely constant. They are also fairly inefficient, at least compared to a fixed belt/chain drive.
Anyway, you are going to want to look at a fixed belt drive system with about a 3:1 reduction. Dig around in the ultralight airplane communities, lots of those guys are using rotax engines that are relatively similar to snowmobile engines, at least in powerband/rpm. They will have suitable belt drive reduction systems.
3) 2004 Yamaha Warrior
4) 2006 Yamaha Nytro
