How to figure out cc's after boreing - Snowmobile Forum: Your #1 Snowmobile Forum
Old 05-27-2012, 10:32 PM   #1 (permalink)
Roof_991's Avatar
Does anyone know a formula to figure outthe cc's of a snowmobile engine after having it bored
Sent from my SCH-I500 using Snowmobile.com App
Roof_991 is offline   Reply With Quote
Old 05-28-2012, 12:57 AM   #2 (permalink)
Terrain Dominator
JD8345RT's Avatar
π • radius2 • height = cylindrical volume
This way will hurt your head less: Calculating the Volume of a cylinder
1993 Polaris XLT Special
1972 Arctic Cat Panther
Old 05-28-2012, 06:59 AM   #3 (permalink)
What are you boreing?
Old 05-28-2012, 10:15 AM   #4 (permalink)
Bore diameter times stroke length.
Add the percentage difference between the original and the new bore.
So. if the original was 67mm D x 68mm S, that would equal 4556mm volume.
over bore of 0.010 equals 45.56mm additional volume which added to the original equals 4601.56 cubic mm.
Old 05-28-2012, 11:51 AM   #5 (permalink)
Volume of a cylinder is as JD stated or as follows
pi x bore x bore / 4 x stroke = volume.
so in RJ's example, 3.1416 x 67mm x 67mm / 4 x 68mm = 239744.9 cubic mm. Divide that by 1000 to get cubic cm and you get 239.7 cc.
Doing it JD's way
3.1416 x 33.5mm x 33.5mm x 68mm = 239744.9 cubic mm
divide by 1000, you get 239.7 cubic cm
That would be for one cylinder, multiply by number of cylinders for total displacement. There is a slight difference between calculating as above and using the calculator JD posted, is the difference in the value of pi used in the calculation.
Add a .010" overbore, that would look like this
Convert inches to mm
.010" = .254mm
67mm + .254mm = 67.254mm (new bore diameter)
3.1416 x 67.254 x 67.254 / 4 x 68 = 241556.1 cubic mm
Divide by 1000 to get 241.6 cc.
241.6 - 239.7 = 1.9 cc increase in displacement for a .010" overbore.
I know this is right because my 11th grader checked my work
Old 05-28-2012, 02:01 PM   #6 (permalink)
Terrain Dominator
JD8345RT's Avatar
Now let's tackle dome heads and calculate the volume of a hemispherical combustion chamber!
Old 05-28-2012, 03:12 PM   #7 (permalink)
I'll have my son get back to you on those
(seriously, the kid is crazy talented at math... he had already completed HS senior calculus before he was in 9th grade!)
Old 05-30-2012, 06:38 AM   #8 (permalink)
Cyl is easy. Just a piece of plexy glass with a small hole. With the spark plug in, put a little grease around the edge and set the plexy on it. With a gradeuated beaker or turkey baster, or suringe, add water till it starts to come up in the hole. That is the volume of the head!
Now with that volume and the volume of the cyl, you can divide them and get your compression ratio!
Old 05-31-2012, 03:31 AM   #9 (permalink)
Now my head hurts...
1999 Ski Doo Grand Touring
Old 05-31-2012, 08:18 AM   #10 (permalink)
PPE. Wear a helmet when you do math, your head won't hurt
Or is that tin foil? I forget!
Old 05-31-2012, 10:12 PM   #11 (permalink)
ride till your broke
Renagade's Avatar
anything will help, while i pound my
head against the wall from confusion!!
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e-mint!!
Old 06-01-2012, 07:07 AM   #12 (permalink)
It's a tin foil helmet! Geez you rookies!
Old 06-01-2012, 03:43 PM   #13 (permalink)
ZR rider
TwinsofMLB's Avatar
Skip a step: bore x bore x stroke x constant x number of cylinders. Constant = 0.7854.
Old 06-01-2012, 03:45 PM   #14 (permalink)
ZR rider
TwinsofMLB's Avatar
Using cylinder volume and compression ratio, it can be done! pi x 1/2bore^2 x stroke = the second number in the compression stroke (simplified).
Old 06-03-2012, 10:43 AM   #15 (permalink)
Not times 2 times itself or squared
Old 06-04-2012, 07:08 AM   #16 (permalink)
My thought exactly,,,,
hosehoundfr86 is offline   Reply With Quote
