What are some good performance upgrades but not to expensive - Snowmobile Forum: Your #1 Snowmobile Forum
Old 05-16-2012, 11:53 PM   #1 (permalink)
zdw0889's Avatar
I got a 96 Polaris ultra 680 sp want to do some small upgrades for a little more power. Already ordered studs any thing else?
Sent from my VS840 4G using Snowmobile.com App
96 polaris ultra sp 680 dg can cobra windshield, 89 el tigre ext 530, 98 zr 600 efi, 80 yamaha exciter 440 l/c, 96 cougar 550.
zdw0889 is offline   Reply With Quote
Old 05-17-2012, 12:05 AM   #2 (permalink)
Best bang for the bucks is to make sure the clutching is spot on. A lot of performance is slowly lost as the belt and clutch components wear. You don't notice the loss over time, but when you get things back to spec, it's often like a new sled. Adding a clutch trail kit can also give you a more aggressive ride, as most stock settings are a compromise between top end and acceleration.
Old 05-17-2012, 01:11 AM   #3 (permalink)
zdw0889's Avatar
Ok who makes a good clutch kit for this sled.
Old 05-17-2012, 09:39 AM   #4 (permalink)
Erlandson makes some pretty efficient kits that work well. I have one in my 650, it made a lot of difference in how aggressive the sled shifted.
EPI Performance ATV and Snowmobile Clutch Kits: - Snowmobile Shop
Old 05-17-2012, 06:05 PM   #5 (permalink)
Goodwin Reformance (847) 872-4001. Greg can hook you up.
Have you started with a compression test at wide open throtle? You should have about 130-135#!
Old 05-17-2012, 06:12 PM   #6 (permalink)
zdw0889's Avatar
Yea but not full throttle and had 120 in two cylinders and 119 in the other
Old 05-18-2012, 07:04 AM   #7 (permalink)
zdw0889's Avatar
Is a spi a good clutch kit for this sled
Old 05-19-2012, 06:59 PM   #8 (permalink)
I perfer Greg he can give you the personal touch and with upgrades he can then mod the kit to fine tune for what you have!
Go back and redo the compression test @WOT!
