Snowmobile engine in go kart! - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 42 (permalink) Old 03-25-2012, 05:37 PM Thread Starter
eli346's Avatar
Yup another one of these threads! After seeing my uncles neighbors srx 700 powered kart throwing 50 ft roosts its made me want to start the project ive been thinking of for a while. I have been toying with the idea of putting the jag motor in a kart for a while now. I tried searching it but what i really want to see is pictures i cant find any. Im thinking it'd be easiest to put the engine on the mount the jackshaft with the secondary and everything on the cart. how do you guys think i should go about mounting the jackshaft to the kart? Then from the jackshaft to the axle? no sure how to go about that part. Cant picture things in my head very well so maybe someone has pictures or could give a detailed explanation?
1989 arctic cat jag afs 440(small project)
1990 yamaha phazer 2
The new money pit
eli346 is offline
post #2 of 42 (permalink) Old 03-25-2012, 08:12 PM
ski doo
sounds like a fun idea but i have no idea
Ski Doo tnt 500ss Mine
Ski doo Renigade Dad
Ski Doo mxz 380 Bro
Honda Crf 150 Mine
skidoo tnt500ss is offline
post #3 of 42 (permalink) Old 03-25-2012, 08:23 PM Thread Starter
eli346's Avatar
I'm also trying to decide if I want to go with a off road design or a street design. it'd be a blast to take to the dragstrip this summer
The new money pit
eli346 is offline
post #4 of 42 (permalink) Old 03-25-2012, 09:04 PM
Quoted: 143 Post(s)
I had one and the biggest problem is the straight axel! The Honda Odesy had the same problem! I just doen't want to turn! If you can, get a differential rear end out of a Quad!
Personally I'm going to use a Tracker front end and just narrow up the half shafts!
kccats is offline
post #5 of 42 (permalink) Old 03-25-2012, 09:18 PM Thread Starter
eli346's Avatar
I was looking at quad rear ends earlier but I'm looking for a budget build! if I had the spare cash laying around id have bought a bike like I really want this just seemed like a good project because I already had the stuff I need for the most part
The new money pit
eli346 is offline
post #6 of 42 (permalink) Old 03-25-2012, 09:23 PM
Quoted: 143 Post(s)
Well it would be cheaper to just put an ATV tire on the Jag!
kccats is offline
post #7 of 42 (permalink) Old 03-25-2012, 09:38 PM Thread Starter
eli346's Avatar
That sounds much more difficult lol I just want a summer toy! I have a good idea of how ill do it but I don't have the frame here to see how it'd all fit
The new money pit
eli346 is offline
post #8 of 42 (permalink) Old 03-26-2012, 02:59 PM
Terrain Dominator
JD8345RT's Avatar
I wouldn't bother with the jackshaft. Build it as a direct drive with the secondary right on your final output, and gear it down with the drive chain for the straight axle.
2012 Arctic Cat XF 800 Sno Pro
2011 Polaris Rush 800 Pro-R
..& Leafers
JD8345RT is offline
post #9 of 42 (permalink) Old 03-26-2012, 03:22 PM
Do a search of this forum and you will find several threads about similar builds.
post #10 of 42 (permalink) Old 03-26-2012, 04:12 PM
Quoted: 143 Post(s)
UHH how would you gear it down without a jack shaft?
kccats is offline
post #11 of 42 (permalink) Old 03-26-2012, 04:13 PM
Terrain Dominator
JD8345RT's Avatar
Think of the drive chain as a big, open chaincase.
..& Leafers
JD8345RT is offline
post #12 of 42 (permalink) Old 03-26-2012, 04:20 PM Thread Starter
eli346's Avatar
what your saying is pretty much the same as it would be using the jackshaft off the sled
The new money pit
eli346 is offline
post #13 of 42 (permalink) Old 03-26-2012, 04:26 PM
Quoted: 143 Post(s)
You will HAVE to use the Jack Shaft to do that! The drive clutch on one end and the sprocket on the other, and a chain to the axel!
A direct drive would have the driven clutch on the axel!
kccats is offline
post #14 of 42 (permalink) Old 03-26-2012, 04:53 PM Thread Starter
eli346's Avatar
My friend is putting an atc 200 motor in his cart so I'm going to let him do his first and learn from his mistakes lol.
How should I mount the jackshaft to the cart? on the sled it goes through a peice of metal and has retainers on each side of the bearing then the other side is mounted in the chaincase how should I mount it on the cart? I saw somebody who just cut the bottom half of the chaincase off and mounted it in that but cutting the chaincase in half just seems kind of wasteful when I could sell it
The new money pit
eli346 is offline
post #15 of 42 (permalink) Old 03-26-2012, 05:13 PM Thread Starter
eli346's Avatar
Im liking this setup
The new money pit
eli346 is offline
post #16 of 42 (permalink) Old 03-26-2012, 05:17 PM
Terrain Dominator
JD8345RT's Avatar
That's what I'm saying. But do away with the full length jackshaft for the sake of compactness. Mount the clutch right next to the chaincase, (or sprocket) like an old sled, to keep the system as inline as possible.
..& Leafers
JD8345RT is offline
post #17 of 42 (permalink) Old 03-26-2012, 05:22 PM Thread Starter
eli346's Avatar
People do cut the jackshaft down so its not so long but i like the setup of the one i just posted
The new money pit
eli346 is offline
post #18 of 42 (permalink) Old 03-26-2012, 06:13 PM
Quoted: 143 Post(s)
If you look at those blueish colored bearing blocks they are readily avalibale!
kccats is offline
post #19 of 42 (permalink) Old 03-26-2012, 06:27 PM
Sconnie
jKsled's Avatar
its not as cheap as you expect!! I did it once! of course it didn't turn, as mentioned above. Used front hubs from a 4 wheeler (and brakes) rear straight axle with 4 wheeler tires.
Pry spent about 350 bucks on it, and way too much time. got the tubing for free. its been sitting for the last two years, after the brakes failed. and the rear axle is so wide, never took the time to cut it down to a more appropriate size.
biggest problem you'll run into is suspension. it took a long time to figure that out. independent front, no suspension in back. originally was just going to have a rear swing-arm but wanted to finish it so said screw it.
onle pics I have. lost the ones after completing it as I broke that phone. been sitting outside the shed for two years now lol. might have to put in on CL
ID:	18987   Click image for larger version
1992 Polaris RXL 650 EFI
1990 Skidoo Formula MX 470
1997 Skidoo Grand Touring 500
1997 Arctic Cat Pantera 580
1979 Ford F150
~360 5.9L, Edelbrock intake, 4bbl carb, 4 speed, divorced transfer case, 3" body lift, 3" suspension lift, 33's, redone interior.
2003 Dodge 3500 srw 6spd
1981 Suzuki GS850L
jKsled is offline
post #20 of 42 (permalink) Old 03-26-2012, 06:34 PM
Quoted: 143 Post(s)
I had over a grand in mine! I had Cavalier front A arms and hubs! I went as far as to get the doughnut spares and put tractor front tires on it!
kccats is offline
