Break problems... jammed! - Snowmobile Forum: Your #1 Snowmobile Forum
Old 03-05-2012, 12:33 PM   #1 (permalink)
After FINALLY getting some snow, I got to ride my snowmobile. It was simply to get it moved from my old home to my new one without having to load it onto a trailer or truck (which I would have to borrow).
After test driving my Ski-Doo 97' Touring LE, I found that my breaks would not release. So I parked it and decided to get them apart and ride it in the daylight. I thought I got the pads off the rotor but apparently not. When I got to the end of my ride home, I hit the breaks and there was no tension on the lever... I had NO breaks! When I made it home, I opened the hood and threw a handful of snow onto the break and of course, it hissed and evaporated FAST.
Does anyone have any ideas on what I should replace/fix first? I've never worked on a snowmobile before. It looks easier than a car though! This snowmobile had been sitting for about 10 years, due to not getting snow and then we just didn't get to use it. It runs great after having the carbs cleaned but the breaks are just acting up.
flipjarg is offline   Reply With Quote
Old 03-05-2012, 06:14 PM   #2 (permalink)
The brake ruber hose has colapsed! Replace it. I recomend the Stainless Steel type!
Old 03-05-2012, 07:42 PM   #3 (permalink)
Awesome, thanks for the help. I will buy one and replace it myself. I was expecting to have to get a new caliper! That rubber hose, is that just preasurized... no cable inside?
Old 03-05-2012, 11:19 PM   #4 (permalink)
Terrain Dominator
JD8345RT's Avatar
Yes
1993 Polaris XLT Special
1979 Arctic Cat El Tigre
1972 Arctic Cat Panther
Old 03-06-2012, 04:08 AM   #5 (permalink)
Master cylinder on the bar is probably the culprit. My 99 Touring had the exact same problem. I replaced the master cylinder and it's been good ever since.
Old 03-06-2012, 06:47 AM   #6 (permalink)
My SLE has cable actuated brakes. Similar to the brakes on a 72 TNT except for the parking mechanism. You guys sure that this LE (two up 440 fan) has hydraulic brakes?
If it's cable, I would check to see that the cable is free in the housing. Make sure the parking brake isn't on. Check the automatic adjuster.
96 Ski-Doo touring SLE
97 Indy Trail Touring
01 600 Edge-X
73 250 AC Eltigre
72 335 Ski-Doo Oly
71 L340 AC Panther
palmrose2 is offline   Reply With Quote
