Originally Posted by Jotch
Its not perfect, but it works. Just need to paint it.
Looks good!
You didn't show any pic's of how the ramps attach to the deck when they are out. I don't see a 2nd hole for the cross bar, so I'm wondering how you do this. Can you send a pic of this as well?
My hinge pins come out easy, so I usually remove the back 1/2 of the ramp when not in use as well, do yours come apart easy? Also - I added a 3rd hinge in the center to help disribute the rear end weight, although your sled is not as long so this may not be an issue for you. You can tell if the back section deflects, then it might be good to add a hinge.
I have another buddy who is planning to build one of these as well.
