when to change slides - hyfax - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 9 (permalink) Old 03-13-2011, 09:13 PM Thread Starter
bassman
well, the snow is all gone here. My sled has 878 miles on it. When do ya need to change the slides on the rails? Does the track have to come off to do this?
bassman is offline
post #2 of 9 (permalink) Old 03-13-2011, 09:23 PM
On most sleds you can pull them back through a track window. Check the curve on the front of the skid for wear, they wear out there first.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #3 of 9 (permalink) Old 03-13-2011, 09:30 PM
That's all u rode this season?
Sent from arctic cats iPhone
Jackmansleddin is offline
post #4 of 9 (permalink) Old 03-13-2011, 10:07 PM
Alex
600RacerX's Avatar
heck that's not that bad. For a while there we didn't have enough snow/time to get any miles on.
How many have you put on this year jackman?
And to the OP- there is a wear line on the side of them to tell you when they are worn out, if you didn't already know that.
600RacerX is offline
post #5 of 9 (permalink) Old 03-14-2011, 09:30 AM
Quoted: 142 Post(s)
If you look at your new slide and Eye ball it with a wrench, either a 1/2 or a 12mm would be as thin as you would want to go! Now slide the wrench along the hyfax and see if it slips on, Replace them! Or wait till fall and do it before it gets cold?
kccats is offline
post #6 of 9 (permalink) Old 03-14-2011, 10:59 AM
gbousum's Avatar
Look at the very front of the hifax and compare the thickenss (of the tip) to the thickness in the middle, around where you sit (where the most weight is over the slides). If there is a significant thickness difference, then you need new hifaxes. Some are easy to take off, some are more difficult. Best thing I found is to get the end out of a window in the track, drill a hole in it, tie a sturdy peice of cord through the hole and put a heavy bar on the end of the cord and yank on it until the slide comes out. Also, have someone holding the track and moving it back and forth to allow the hifax to slide out.
gbousum is offline
post #7 of 9 (permalink) Old 03-14-2011, 11:33 AM
JDS
JDS's Avatar
I found out this winter that if you use a heat gun to heat up the hifax, it comes off really easy.
JD
____________
2008 Polaris RMK 600-155"
JDS is offline
post #8 of 9 (permalink) Old 03-14-2011, 12:21 PM Thread Starter
bassman
thanks guys. I am new to the sport and am learning from all of you.........bassman
bassman is offline
post #9 of 9 (permalink) Old 03-14-2011, 10:34 PM
rcslsafut's Avatar
most of my sleds have a line in the hyfax to give a limit indicator if you will , its about
a quarter of an inch off the bottom, you hit the line , they are wore out !
the ole boy i work with puts any where between 1200- 1500 miles a year , wears out a set every year, has a lot to do with where you ride , how you ride , how many bogie wheels on you rails will help or not on hyfax wear !
rcslsafut is offline
