91 arctic cat problems - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 8 (permalink) Old 12-21-2010, 05:37 PM Thread Starter
I just bought a 1991 arctic cat el tigre ext 550. it has been sitting for a couple years and i had to rebiuld the carbs. ran good for a while then it seemed like it was runnin on one cylinder and died. got it started again but still does the same thing every so often but if i play with the throttle when its bogged down i can save it and then it runs ok for a couple hundred feet then does it again. also the only way it starts is if i put the choke on for a 7 or 8 pulls without the key on then turn on the key and hold down the gas and then start it.
bsperls is offline
post #2 of 8 (permalink) Old 12-21-2010, 08:02 PM
You cleaned the carbs, but I bet you didn't drain the old fuel and clean out the tank. The pump picked up all the crud off the bottom of the tank and pumped it into the carbs.
Start over clean everything out real good.
The path less taken has thy best powder!
Mrdman2442 is offline
post #3 of 8 (permalink) Old 12-21-2010, 08:24 PM
ZR rider
TwinsofMLB's Avatar
Replace ALL of the gas lines, too. The pickup line in the tank should come first.
TwinsofMLB is offline
post #4 of 8 (permalink) Old 12-22-2010, 07:12 AM
Quoted: 142 Post(s)
And what is your compression? At Wide Open Throtle?
kccats is offline
post #5 of 8 (permalink) Old 12-22-2010, 08:48 AM Thread Starter
ok i'll try that thanks
bsperls is offline
post #6 of 8 (permalink) Old 12-22-2010, 11:32 AM
compression
Def check compression; I recently had the cable that controlled the oil injection break loose; so sled was only getting the idle setting dose of oil. Burned up a ring, had similar behavior - would run, kindof, for a minute or so...because of very low compression.
Tug Hill NY
1999 Ski Doo Grand Touring 700
1995 Arctic Cat Puma 340
1989 Ski Doo Formula MX 470
1979 Yamaha Excel V 540
1987 Ski Doo Escapade 500 (sold)
1979 Yamaha Excel V 540 (sold)
1985 Yamaha SS440 (RIP)
1990 Arcit Cat Jag 440 AFS (RIP)
OneidaSteve is offline
post #7 of 8 (permalink) Old 12-22-2010, 06:56 PM
ZR rider
TwinsofMLB's Avatar
If it has enough compression to blow your thumb off of each cylinder (one at a time) with both plugs out it should have enough compression to start.
post #8 of 8 (permalink) Old 01-03-2011, 01:03 PM Thread Starter
ended up the throttle cable broke on one of the carbs because the neadle was bent and was causing wear in the carb so i had to get a throttle cable and a ccarb also the kill switch was defective so it had no spark unless throttle was held open runs now put need to tune it
bsperls is offline
