Not getting gas - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 11 (permalink) Old 11-06-2010, 11:23 AM Thread Starter
Not getting gas
Hey guys ive got a 1987 jag 440 i picked up for cheap last year. It ran great all year. I went to start it back up a little while ago, it fired up second pull then died after a few minutes. I saw that the in line filter was all full of junk so i replaced it, but now im not getting any gas even flowing to the filter.
Ive tried a few things iv seen posted about similar problems but nothings working, any advice?
Thanks,
Matt
Matt CT is offline
post #2 of 11 (permalink) Old 11-06-2010, 12:43 PM
ZR rider
TwinsofMLB's Avatar
Before you go any farther, clean your carbs. It's a must before each season if you want your sled to run correctly. Anyway I'd imagine you don't have anything to worry about right now. Just dump a little gas in each cylinder and fire it up while feathering the throttle. Do that a few times and you should start to see the fuel getting closer and closer to the carbs. If that doesn't work, move on to the fuel pumps.
TwinsofMLB is offline
post #3 of 11 (permalink) Old 11-06-2010, 01:33 PM Thread Starter
I cleaned the carb out a few days ago so thats all set. I did put a little gas down the cylinders, iv done this a few times and i can start it and try to give it some gas but then it dies. Also after i did this i noticed some gas/oil coming out of exhaust. That kind of had me worried which is why i decided to post on here.
Matt CT is offline
post #4 of 11 (permalink) Old 11-06-2010, 01:41 PM
Rick
indyryder500's Avatar
look in the tank and see if the line in the tank is still good. If that is good get a rebuild kit for the pump and rebuild it. it might be dirty from whatever was in the filter. but i would look at the line in the tank first. the gas and oil is normal coming from the exhaust. once you get it running let it run awhile and it will burn it all out. thats what will happen when you just start a sled for a few minutes. you need to let it warm up all the way then shut it off. thats when you get it running right again. hope this helps.
97 ultra spx slp can geared clutch and 144 studs.(mine)
96 XLT studded with reverse(12y/o son)
98 xcf 440 (wifes sled)
96 puma 340 elec start(kids sled)
96 cougar 550 2up bone stock (sold)
96 XCR 440 clutched (sold)
92 indy 500 bored,clutched. piped(sold)
85 indy 400 (11 y/o son's sled)(sold)
87 yamaha excel 340 (parting out)(sold)
2011/2012 miles :00000000
indyryder500 is offline
post #5 of 11 (permalink) Old 11-06-2010, 02:04 PM
Live to ride
99Polaris500's Avatar
Quoted: 2 Post(s)
make sure you gas line didn't fall out of the tank(not sure how to eplain it any better).
that happend to my old jag.
does it start if you pour gas down the cylinders?
'99 Polaris xc 500
a few Arctic Cat prowler 440s
99Polaris500 is offline
post #6 of 11 (permalink) Old 11-06-2010, 09:49 PM
Rick
easy way to find out is take as much gas out the tank as you can. then at the front of the tank you will be able to unscrew the feed line out.
post #7 of 11 (permalink) Old 11-07-2010, 06:26 AM
skidoostud's Avatar
Make sure your fuel is on! I spent 3 hours trying to start my snowmobile with the fuel switch off...and I don't think a jag has a fuel switch but anyways, after that, check all your lines leading up to the gas tank. It wouldn't surprise me if its plugged up somewhere in the gas tank itself.
Current Sleds-
95' ski doo Mach z 780 triple (stock)
98' ski doo formula sl 500 (Stock)
98' Arctic cat 440 Jag (studded)
Previous Sleds-
00' Mxz 700
1992 Ski doo Mach 1 (DG pipe)
1976 El Tigre 5000
1972 Arctic Cat Panther 440
"Ride em' till you can't feel your toes"
skidoostud is offline
post #8 of 11 (permalink) Old 11-07-2010, 05:18 PM
Rick
my 88 didn't have a shut off.
post #9 of 11 (permalink) Old 11-07-2010, 05:44 PM Thread Starter
Yea theres no fuel shut off so thats not the problem. I feel like it is probably the line in the tank but i have to head back to college so it has to wait till next weekend. thanks for all the advice and ill have to check it out when i go back home.
Matt CT is offline
post #10 of 11 (permalink) Old 11-07-2010, 05:46 PM
Make sure that the fuel line in the tank did not rot and break off that is what happened on my polaris indy 500 it will still run with what gas is left in the lines but not for long.
polaris500500 is offline
post #11 of 11 (permalink) Old 11-07-2010, 05:56 PM
Rick
lol read the hole tread.
