02 xcsp 600 compression psi? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 7 (permalink) Old 05-14-2010, 03:51 PM Thread Starter
Quoted: 2 Post(s)
anyone know what kind of compression i should have? 02 xcsp 600
zobenv is offline
post #2 of 7 (permalink) Old 05-14-2010, 03:55 PM
Yamaha 4 Life!
TheSnowPro's Avatar
anything over 120-125 and both cylinders should be within 10% of each other. if you dont trust the gauge you're using then test with it, then with a different gauge and compare the readings.
Mine - 1989 Yamaha Phazer 485 w/ Comet 102C and boyesen power reeds. 14,356 kms.
Dads - 1997 Yamaha V-max XT 600 stock w/ polaris P-85 clutch
Brothers - on its way home soon! either a yamaha or skidoo. not sure what yet.
First ride of the 2009/2010 season - 11/12/09
09/10 km's - over 1200. pretty good for only half a seasons worth of riding.
TheSnowPro is offline
post #3 of 7 (permalink) Old 05-14-2010, 03:56 PM
Quoted: 94 Post(s)
Depending on elevation, 120-140 would be pretty normal. Some will go as high as 150. If it's below 100, that would indicate a lot of wear. 100-120, I would be watching it, but would not tear it down unless there was another problem to fix, unless it was really hard to start or didn't have the power it once had...
BC_Dan is offline
post #4 of 7 (permalink) Old 05-16-2010, 07:43 AM
Quoted: 130 Post(s)
Alot of the Polaris had realitivly low compression even new (125) Alot would depend on millage! If you have over 3000mi and your compression is at or below 120# @WOT I would take it down and freshen it!
kccats is offline
post #5 of 7 (permalink) Old 05-17-2010, 08:48 AM Thread Starter
Quoted: 2 Post(s)
what do you look for on a tear down. we looking at repl pistons, rings, replate cyl? or if everything is in good shape re-ring it?
i have alot of experience with race stuff but not 2 stroke. i need to learn the lengo. my logic tells me to measure the cyl, the piston if they are within spec re-ring it.
is my 02 polaris xcsp 600 nikasil??
thanks for the help.
zobenv is offline
post #6 of 7 (permalink) Old 05-17-2010, 09:06 AM
You got it right.
post #7 of 7 (permalink) Old 05-17-2010, 05:50 PM
Quoted: 130 Post(s)
Look at everything, look for hair line cracks in the pistons. Look for scratches in the walls. Look for pits in the heads.
kccats is offline
