Old 11-04-2009, 09:43 PM   #1 (permalink)
brianph09
arctic cat zl 600
what would make my snowmobile rev out way to high? Its like its not hitting the overdrive and just wants to keep going bu.t i dont want to blow it up. Id this the clutch acting up
brianph09 is offline   Reply With Quote
Old 11-05-2009, 08:17 AM   #2 (permalink)
kccats
A coupla things to look at! Is it reving with out moving the throtle! Air Leak! If it idles ok but as you run it it goes over 8500, then it could be the belt and or a broken driven spring!
Old 11-05-2009, 08:47 AM   #3 (permalink)
brianph09
It only seems to do it full throttle at high speed.
Old 11-05-2009, 12:57 PM   #4 (permalink)
How old is your belt?
Old 11-05-2009, 01:24 PM   #5 (permalink)
brianph09
It is older i bought the sled at the beginning of last year and it was on there when i bought it. It doesnt look to be bad or anything though.
Old 11-05-2009, 04:10 PM   #6 (permalink)
I suggest that it might be time for a new belt to start with.
Old 11-06-2009, 08:41 AM   #7 (permalink)
brianph09
I will try it and see what happens. Thanks
Old 11-06-2009, 08:51 AM   #8 (permalink)
kccats
OK next how high is it reving? Could be that the belt is just worn (narrowed) or a broken spring in the secondary!
Old 11-06-2009, 12:05 PM   #9 (permalink)
brianph09
It would rev up to 9000 rpm and it wanted to keep going but i would always let up. I put a new track on last year without studs and I would really notice it on slick dirt roads or trails once i was already up to about 40 or so and punch it. Would i be able to see if the spring is broke in the secondary or do i have to take it apart.
Old 11-06-2009, 07:10 PM   #10 (permalink)
kccats
I would look close at the driven clutch and belt!
Old 11-09-2009, 09:14 AM   #11 (permalink)
brianph09
Ok I tore apart my sled this weekend. I dont really see anything rong with the clutch at all the spring is good and the belt doesnt look to be bad at all. I was told by someone that my secondary should have a little bit of play in it is that true. I am still tring to figure out why this thing is over reving.
