Old 11-03-2009, 09:06 PM   #1 (permalink)
jvince
indy 500efi
Talking 97 xlt 600 trouble starting
hello every one....my xlt triple 600 is givin me a very hard time starting...when it does start in runs awesome...but once it sits over night and i go out to to start it, it takes for ever to start, it will fire a little bit and a little bit then it will finaly start....i use the choke at first then when it fires i put it down to the next then it will fire again then i put it down to the next it will fire again then i take it off then it just fires then shuts off....so i give it a little gas as i pull it over and then it will spit and spuder and then finaly run...thats the best as i can exsplain sorry....i have no idea were to start, this is my first year for sleds...tomorow im goin to start with the carbs and clean them 1 by 1...ive allready put new plugs in...it seems like it might be gettin to much fuel...if i take out the plugs and pull it over a few times then put them back in it fires right up for a second....so if any one can help me please that would be awesome.....
jvince is offline   Reply With Quote
Old 11-04-2009, 01:27 AM   #2 (permalink)
kevin2502000
My Xcr only needed the choke when it was really cold out, you sure you.re not just flooding it? Also once the plugs are flooded you can't trust them. If it is flooded, take the plugs out, pull it over a few times with the throttle pinned and the key off. Walk far away from the sled and get a propane torch and heat up each of the plugs fairly warm and re-install them and try it. You might have to repeat that a few times to get it dried up. Once it starts let it run a few minutes to clean it out.
kevin2502000 is offline   Reply With Quote
Old 11-04-2009, 08:22 AM   #3 (permalink)
Try starting it without choking at all.
Your carbs are in need of cleaning/adjustment.
Either the needle valve is not seating properly allowing the base to flood, or the chokes (enricher circuit) are not closing completely when off.
Old 11-04-2009, 09:43 AM   #4 (permalink)
Ultrafrozen
Ultrafrozen's Avatar
I know it's not that cold out yet unless you're up in northern Alberta but a high mileage 1997 XLT Touring I used to own had the same issue in the cold.
Moisture (powder snow or snow dust on the trail) would freeze something up in the cleaned carbs and not allow an eazy start if I hadn't used gas line antifreeze. The only solution was to run an electric heater pointed at the carbs for a few minutes and all was good after that.
1994 Skidoo Grand Touring 580
1997 Polaris Indy 500 classic
Old 11-04-2009, 03:14 PM   #5 (permalink)
jvince
indy 500efi
ok i just took out 1 carb and WOW...its full of white flakey stuff in side of the bowl???? im tryin to clean it off and not all of it will come off, so wat can i use to get it all off...and there was allmost like water in it....little beeds of water...it was beeding like water does when its with gas if you no wat im saying....so lets hear wat i should do, please and thanks every one for helping....i think once i get them all cleaned up it should fire up right way every time...never seen it before in my dirt bikes
Old 11-04-2009, 04:17 PM   #6 (permalink)
kevin2502000
THOROUGHLY clean all the carbs with carb cleaner and compressed air. If the bowls still turn white after they dry, douse them with wd-40 and then let the aluminum soak it up and season it. Make sure you pull out all the jets and blow through the passages. You need to check the float height before buttoning up and then lastly re- synch. I would drain your tank also.
Old 11-04-2009, 06:30 PM   #7 (permalink)
jvince
indy 500efi
how do you check the float hight??????
Old 11-04-2009, 06:36 PM   #8 (permalink)
Turn the carb over (upside down), the levers for the floats should be parallel or slightly down to the body of the carb bowl seal.
