Old 11-01-2009, 08:11 AM   #1 (permalink)
kingston_rider
I need new primary clutch weights, change or go stock?
Hi, I pulled apart the primary clutch off my 1998 arctic cat panther 550 to diagnose a rattle in the clutch at low rpms. What I found was some play in the sheave bushing, I think a normal amount, the other thing I found was the bushings on my weights were so worn that that two of the weights are now worn oval where the bushing were as they had rubbed against the mounting bolts. The weights are OEM and 50.5 grams, should I increase the weight at all or stay the same, this is a trail sled, 1 and 2 up riding, any advantage to increasing the weight? Any advice is appreciated, John.
kingston_rider is offline   Reply With Quote
Old 11-01-2009, 09:10 AM   #2 (permalink)
Just replace them, keep it stock.
Old 11-02-2009, 07:53 AM   #3 (permalink)
kccats
You can get just the fiber bushings ($3 for set) or order 51 gram weights ($40 set)
Old 11-02-2009, 11:17 AM   #4 (permalink)
kingston_rider
I ordered thru the dealer today, $22 each weight with bushing, $8 per pin.
Old 11-02-2009, 07:06 PM   #5 (permalink)
kccats
WOW thats $66 and $24 more!
Old 11-03-2009, 06:49 AM   #6 (permalink)
kingston_rider
Yeah I know, when I checked with online they were not available in a set, where did you get that price?
Old 11-03-2009, 08:04 AM   #7 (permalink)
kccats
HPE and Fowler Dist! Heck man I prob had a set! I know I have the bushings! As long as the weights aren't worn the bushings are the way to go!
Old 11-03-2009, 09:54 AM   #8 (permalink)
kingston_rider
Weights are worn, oval shaped, ah well, I am in a hurry to get this thing finished so went with dealer vice shopping around, I have never used HPE or Fowler, usually use Royal and they don't stock for my sled, will check them out for future needs, thks.
Old 11-04-2009, 08:58 AM   #9 (permalink)
kccats
High Performance Engineering, Hi-Performance Engineering!
Fowler Distributors,Fowler Distributors : Welcome !
