Old 10-10-2009, 10:52 PM   #1 (permalink)
snowtrax00
Question Is it hard to convert a gas sled to a diesel?
What has to be done to convert it to diesel. I like how they dont rev high at all and they're effortless. How much would it cost to convert a 2stroke to a diesel?
snowtrax00 is offline   Reply With Quote
Old 10-11-2009, 01:33 AM   #2 (permalink)
Ultrafrozen
Ultrafrozen's Avatar
I can do it for you for about $153,047. Let me know soon because the orders are piling up.
First I shave the heads to bring compression up from about 8:1 to 17:1. Then I build an oil sump to lubricate the crankshaft bearings, install my patented "two stroke diesel injectors", modify the spark ignition system and install the antigelling fuel heaters for those cold mornings. You have a choice of reclutching for the low engine speeds (included), or for an extra $63,000 I can install a two speed transmission. Reverse is an extra $13,000.
JUST KIDDING! I couldn't resist. The modern two stroke engine is not robust enough to handle the high compression ratio. Two cycle diesels are very heavy. I think model airplane engines run on a fuel similar to diesel. maybe you can look at that technology to make it work.
You would have better luck converting a four stoke sled.
1994 Skidoo Grand Touring 580
1997 Polaris Indy 500 classic
Old 10-11-2009, 03:52 AM   #3 (permalink)
flandersander
flandersander's Avatar
If I were you, I would go the other way. Go to a Higher reving fuel like ammonium nitrate or gun powder. Yeah, a 600cc gunpowder engine. You think 100 grains makes a big bang? Try 6000! BOOOOM!
The good you do will live long after you're gone
flandersander is offline   Reply With Quote
Old 10-11-2009, 08:49 AM   #4 (permalink)
snowtrax00
What if I wanted to convert a four stroke instead?
Old 10-11-2009, 10:21 AM   #5 (permalink)
polaris rider
PR (polaris rider)
polaris rider's Avatar
how bout you buy a 4 stroke then? Dude, u got a 2 stroke.. leave it that way
1999 AC zl 500, 3k miles2003 polaris classic 340 1200 miles-2003 polaris indy xc 500 1500 miles-2000 polaris xc 700 6500 miles-2003 arctic cat zl 600 1500 miles
"Dont let fear and common sense stand in your way!"
polaris rider is offline   Reply With Quote
Old 10-11-2009, 11:46 AM   #6 (permalink)
Look up "clean sled challenge", University of Buffalo put a 3cyl turbo diesel in to a Poo frame.
Old 10-11-2009, 12:16 PM   #7 (permalink)
xcelr800
xcelr800's Avatar
i know they make an electric sled ,but only goes 20 miles or so my .02
XCR 800 SEE AT THE FINISH LINE!!!!
xcelr800 is offline   Reply With Quote
Old 10-11-2009, 12:17 PM   #8 (permalink)
stickshift69
stickshift69's Avatar
Its impossible with the original engine.
2003 ProX 700
1993 XLT SKS
1996 XP800, Full Mod
stickshift69 is offline   Reply With Quote
Old 10-11-2009, 12:18 PM   #9 (permalink)
SkiDoo86
Converting a two stroke to a diesel would be about how GM converted the Chevy 350 to a diesel back in the day. And we all know how that worked out.
SkiDoo86 is offline   Reply With Quote
Old 10-11-2009, 03:41 PM   #10 (permalink)
BC_Dan
ROFL, that's funny right there
Converting your sled to diesel is possible, using a different engine, gear ratio, and clutching setup. Converting your gas powered 2-stroke to diesel is not possible, the design just won't allow such a conversion. Like Ultra said, the gas engine just isn't strong enough. Neither was Chevy's 350
Old 10-11-2009, 04:16 PM   #11 (permalink)
SkiDoo86
I see where he might of gotten the idea of a two stroke diesel. Back in the day Detroit Diesel made a two stroke diesel. But it is no where near the concept of a snowmobile engine. Produced mad power, but also guzzled fuel and not very clean. Only way to make a Detroit Diesel like that to stop leaking oil, it to drain the oil.
You physically couldnt get enough compression out of the two stroke to ignite the diesel. First thing to go would be the crank... And imagine that its the same thing that went in the Chevy 350's, no wonder they went bankrupt.
Old 10-11-2009, 04:50 PM   #12 (permalink)
phishook
phishook's Avatar
what about LP?
Still pointless, IMO, but if you have the time...
79 JD 440 Trailfire
81 JD 440 Liquifire
83 Yamaha 400 SS
01 AC ZR800
phishook is offline   Reply With Quote
Old 10-11-2009, 06:51 PM   #13 (permalink)
BC_Dan
Even in the day, the Jimmy diesel was big and heavy, and had a crankcase, even though it was a 2-stroke. It did make a LOT of power compared to the other similarly sized diesels of the time.
First time someone said something about a diesel sled, I thought there was NO way.. the engines are way too heavy and diesel fuel is not really a great performer for cold weather... then they did one...
2005 Polaris Fusion - Diesel Engine - Diesel Power Magazine
Anything is possible, but is it marketable? And would I buy one? Would you?
Old 10-12-2009, 08:57 AM   #14 (permalink)
kccats
The LP would be possible! I've often thought about the Cox engine! I don't think the fuel was a form of diesil, likely more the other way, Naptha!
Old 10-12-2009, 06:54 PM   #15 (permalink)
jKsled
Sconnie
jKsled's Avatar
try electric! Clean sweep for UW-Madison snowmobile team (March 24, 2009) the uw's electric sled is faster than a lot of gas sleds! top speed of 75 but the acceleration is crazy, i've seen it in person. 100hp. won first place, and so did the IC sled they designed too....
1992 Polaris RXL 650 EFI
1990 Skidoo Formula MX 470
1994 Chevy Camaro basically stock
1986 Ford Ranger 2.9L 4x4
3"body lift
3" Skyjacker suspension lift
custom exhaust
Old 10-12-2009, 08:26 PM   #16 (permalink)
upersleder
upersleder's Avatar
if it were possible i wouldnt want to be the one pulling on the rope!
2003 MXZ 700X
take the warning labels off everything and let the problem sort itself out
