Why dont my lights work? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 9 (permalink) Old 08-03-2009, 12:43 PM Thread Starter
Trevor
YamahaSS440's Avatar
I have a 1985 yamaha ss440 and my headlight wont turn on. The key is in the right position and they just dont work. The light bulb is fine and the wiring looks to be good. They worked a week ago but now they wont work. The rear light works fine but the front one wont turn on. What could be causing this? Could it be the voltage regulator by any chance?
2009/2010 Miles:900
2010/2011 Miles:1300
2011/2012 Miles:530
2012/2013 Miles:1050
YamahaSS440 is offline
post #2 of 9 (permalink) Old 08-03-2009, 02:43 PM
If the other lights work, it's not the regulator.
Check the hi/lo switch or try another bulb in there.
If still no light, start by checking for broken/melted wires or bad ground.
post #3 of 9 (permalink) Old 08-03-2009, 08:11 PM Thread Starter
Trevor
k, is there anyway to tell if a bulb was working? The lights worked yesterday but then it rained and they stoped working
2009/2010 Miles:900
2011/2012 Miles:530
post #4 of 9 (permalink) Old 08-04-2009, 05:57 AM
Check the bulb with a multi-meter for continuity, if it is good start looking for bad wires or corrosion in the light base it plugs into. I pull all my plug connections apart every year and spray contact cleaner in them and add a drop of oxyguard (electrial grease) in each fitting b-4 putting back together. You will never have a bad connection again that way.
2003 Yamaha RX-1 1000
2000 Polaris 700 XC 45th Anniversary Edition
1997 Polaris Indy 500 Sport
1998 Polaris Indy 500
1996 A Cat panther dlx 440
kikkinurazz3 is offline
post #5 of 9 (permalink) Old 08-04-2009, 11:02 AM
My money is on the switch.
post #6 of 9 (permalink) Old 08-04-2009, 12:42 PM Thread Starter
Trevor
Where can i find an exact replacement switch? Ebay? or is there a way to fix it. I think it could be the switch because high beam usually worked and low beam didnt unless i fiddled around with the wires. So, i might just buy a switch
2009/2010 Miles:900
2011/2012 Miles:530
post #7 of 9 (permalink) Old 08-04-2009, 02:27 PM
Al's Snowmobile Parts Warehouse - Snowmobile Parts, Snowmobile Parts, and More Snowmobile Parts
post #8 of 9 (permalink) Old 08-04-2009, 04:10 PM Thread Starter
Trevor
Good news, the lights work now. I took the dash apart and there was a plug that connected to the switch and it was disconnected. I reconnected it and it works good now. Thanks for the suggestions.
2009/2010 Miles:900
2011/2012 Miles:530
post #9 of 9 (permalink) Old 08-04-2009, 05:09 PM
See, persistence pays off.
