Help with coil test (w/picture) - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 10 (permalink) Old 12-16-2008, 07:54 PM Thread Starter
Will someone please help me figure out the readings of my coil? I am only getting spark at one cylinder (the cylinder that coresponds to lead 4 in the diagram). Here are my readings:
1-2 = .4 ohms
1-3 = 88.5K ohms
1-4 = 0.L
2-3 = 87.5K ohms
2-4 = 0.L
leads 1 and 2 go into the coil, leads 3 and 4 go to the plugs. lead 4 is getting spark, 3 is not. Is this coil and good? I have put new plug caps on and the problem stayed the same. Thanks a ton for the help guys, I really hope to be back riding this weekend.
bluegill81 is offline
post #2 of 10 (permalink) Old 12-16-2008, 08:13 PM
Want a quick fix? Swap coils. If the problem moves, you know it's bad.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #3 of 10 (permalink) Old 12-16-2008, 08:19 PM Thread Starter
My sled is a 2 cyl and only has this one coil, that is why I would like to know if it is bad or not before I go buy a new one.
post #4 of 10 (permalink) Old 12-16-2008, 09:50 PM
x7drvr's Avatar
bluegill, i think SEG is saying to switch the wires on the plugs. i.e. take the wire that goes to the right plug, and put it on the left, and take the left wire and put it on the right
December 08 Sled of the Month
2002 Polaris 600 Edge X
-LED underglows
-Edge Windshield
-M-10 Suspension
98 Indy 500 Classic (bro's)
summer ride: 08 Can-Am Outlander 650XT
x7drvr is offline
post #5 of 10 (permalink) Old 12-17-2008, 06:26 AM
That works too! Didn't know it was a single coil. Swap the plug wires.
1999 Ski Doo MXZ600
post #6 of 10 (permalink) Old 12-17-2008, 05:58 PM Thread Starter
I swapped the plug wires already and the problem is the same. Isn't is possible to tell if the coil is good just from the numbers I got? Thanks again guys.
post #7 of 10 (permalink) Old 12-17-2008, 09:31 PM
x7drvr's Avatar
if it is your coil, make sure you get a good one...OEM may be more expensive, but some of the aftermarket ones are piles of junk
-LED underglows
-Edge Windshield
-M-10 Suspension
x7drvr is offline
post #8 of 10 (permalink) Old 12-18-2008, 06:31 AM
If you did that, the coil is not the problem. The faulty cylinder should have started running. Are you using an inline spark tester to SEE if you have spark? Laying the plug on the engine sucks.
1999 Ski Doo MXZ600
post #9 of 10 (permalink) Old 12-18-2008, 05:40 PM Thread Starter
sorry, there is a miscommunication. when I said that the problem stayed the same, i meant that it still only ran on one cyl. (the opposite cyl. when i switched the wires.) I am pretty sure it is the coil, I will find out tomorrow when the new one comes in the mail.
post #10 of 10 (permalink) Old 12-23-2008, 05:21 PM
you should have a resistance reading at the number 4 at the end of the plug wire since
you don't this means the coil assembly or wire is 0L witch means open circuit so you have a bad coil/wire assembly.
Richgmtech is offline
