02 MXZ 800 high idle issue - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 10 (permalink) Old 09-25-2008, 05:34 PM Thread Starter
DG
Post 02 MXZ 800 high idle issue
2002 mxz 800. idles around 3k rpm. carb boots good, no vacuum leaks, cant pin point problem area. any suggestions
DG1350 is offline
post #2 of 10 (permalink) Old 09-25-2008, 05:54 PM
TRH- Troll Raising Hell
SMFXRSB's Avatar
What exactly have you done to pin point the leaks?
Snow: The other white drug!
SMFXRSB is offline
post #3 of 10 (permalink) Old 09-25-2008, 06:02 PM
Is there 1/8" of cable play in the throttle lever? The cable may be too tight, keeping the slides too high.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #4 of 10 (permalink) Old 09-25-2008, 09:08 PM
bbbbrrrraaaaapppppp??
AvroAero's Avatar
Mine does something similar. After running at high rpm it doesn't go down to a low idle easily. Like to hover at 3k more. If I fiddle the choke a little I can get it down to idle and it'll stay there. Not as common when warm.
AvroAero is offline
post #5 of 10 (permalink) Old 09-28-2008, 09:32 PM
700summitguy's Avatar
I can't find the tech sheet,but there was an issue with airflow inside the carb bypassing the flat slide and causing higher idle speed.Sorry,I can't remember what the fix was.I'll keep looking.
700summitguy is offline
post #6 of 10 (permalink) Old 10-01-2008, 04:27 PM Thread Starter
DG
Thanks. cable adjustment helped!
DG1350 is offline
post #7 of 10 (permalink) Old 10-01-2008, 09:21 PM
Good times.
1999 Ski Doo MXZ600
post #8 of 10 (permalink) Old 09-20-2009, 02:50 PM
2002 mxz 800
I have the same problems.I have at less 1/8 of space there maybe more but if i put her on 1/2 choke she will idle down but as soon as you give her a little gas and let go she shoots right back yup to 3000 rpm.just wondering if you guys know what to do.I have a 2002 mxz renegade 800.
camz72 is offline
post #9 of 10 (permalink) Old 09-20-2009, 06:08 PM
Quoted: 102 Post(s)
Lots of times, a high idle is an indication of a lean condition in the pilot jet circuit. Sometimes installing the next size bigger pilot jet helps, as does turning the air screws in a bit (or fuel screws out, depending on model of carb...)
If it comes down with the choke applied, and you have ruled out air leaks in the carb boots and a leaky crankcase seal, try the air screws...
BC_Dan is offline
post #10 of 10 (permalink) Old 09-20-2009, 08:28 PM
How would ou check for a leaky boot or crankcase seal.do you have to take the carbs off to adjust the air screws
camz72 is offline
