Old 05-16-2008, 11:58 PM   #1 (permalink)
tommac
100%NZ
tommac's Avatar
Riding On Grass/dirt/mud
Hi,
I going sleding tomorrow on my 96 Ski Doo Touring E LT, I'm going to have to sled for about 2 miles on grass, mud, dirt etc before I get full snow cover. Is this going to damage my sled? Whats your opinions on riding on foreign surfaces?
Cheers
Tom Mac
tommac is offline   Reply With Quote
Old 05-17-2008, 01:34 AM   #2 (permalink)
lrnnorth
Above The Arctic Circle
lrnnorth's Avatar
Is it a liquid or fan cooled. A fan would be fine as far as overheating but a liquid you would have to find a couple puddles to run through. You might find you get alot more grip in mud. I found this out the hard way the other day by almost flipping my skidoo over backwards. But i was being dumb. Just watch out for rocks.
01 Polaris RMK 136"
- 01 600 VES Engine - Uni Air Filters
- Sno Stuff Rumble Pack - Powermadd Boost Bottle
- Custom Painted Hood - Powermadd Bar Riser
- EPI Pro Series Clutch Kit
01 Yamaha VK III 540 (The TANK)
Out Of Commission Till Next Year
lrnnorth is offline   Reply With Quote
Old 05-17-2008, 03:04 AM   #3 (permalink)
tommac
100%NZ
tommac's Avatar
I don't even know what my cooling system is, I better find out. I've got the manual here somewhere. Thanls for your reply...
Cheers
Old 05-17-2008, 03:11 AM   #4 (permalink)
lrnnorth
lrnnorth's Avatar
just look at your engine. Does it have plastic around it with a big fan on the side or does it have hoses going to and from the motor.
01 Polaris RMK 136"
Old 05-17-2008, 05:10 AM   #5 (permalink)
BC_Dan
Running in dirt will eat your hifax and wear out the track clips very prematurely as well. Sleds aren't sealed very well against dirt.
Rebuilding the fleet!
Old 05-17-2008, 05:39 PM   #6 (permalink)
I'm fairly certain that the E LT is a fan cooled engine.
It would be better is you can avoid running through the dirt and mud as much as possible. Grass is not so hard on the sled as it has some moisture of it's own and will act as a lubricant, especially if it is wet.
Better to get as close as possible to the snow before unloading.
Old 05-19-2008, 04:37 AM   #7 (permalink)
tommac
100%NZ
tommac's Avatar
So, I went sleding, it was way muddy and quite steep so the sled was not really getting traction on the steeper hills, it's also only a 380. My belt was also slipping quite a bit and smoking so I called it quits, Proper snowfall is only around the corner so I'll wait untill then before I go out again. My poor sled got soooo muddy. I cleaned it the best I could by hosing it thoroughly. Just an update!!
Old 05-19-2008, 06:20 AM   #8 (permalink)
You'll have snow there soon enough! Replace the belt and wait for the good stuff to come!
Old 05-19-2008, 04:17 PM   #9 (permalink)
tommac
100%NZ
tommac's Avatar
Will I really have to replace the belt? It still seems in really good condition. I have 2 spare belts but I would rather save them untill I really need them.
Old 05-19-2008, 04:48 PM   #10 (permalink)
If you smoked the belt, there is now a ) ( in it and that will cause a thumping. (very annoying) And, now that belt is worn down so that it will not give good power transfer to the rest of the drive train, and will cause loss of top speed and power.
