» Site Navigation
» Power Sports Links
Old 02-27-2008, 05:48 PM   #1 (permalink)
z400kiksazz's Avatar
Removing Drive Clutch, need some help
Hey any tips on removing the clutch on a 1991 arctic cat 440?? They call for 0644-100 puller and I dont have that.
heres what it looks like
Arctic Cat Snowmobile Clutch Puller
1991 Arctic Cat Jag 440 AFS
2003 Yamaha R6
z400kiksazz is offline   Reply With Quote
Old 02-27-2008, 07:02 PM   #2 (permalink)
I was thinking take a 12" 3/4 bolt and grinding it down...........
2003 Yamaha R6
Old 02-27-2008, 08:25 PM   #3 (permalink)
jagermiester's Avatar
Gotta be tempered steel or you WILL break it and likely in the clutch. Pullers are and handy tool to have around and compared to the headache of not having one, cheap. Just my .02
98 Jag (for the kids)
03 MXZ-X 800 (Blair Morgan)
Old 02-27-2008, 08:36 PM   #4 (permalink)
TRH- Troll Raising Hell
JheLrey's Avatar
You can always take it to a dealer and have them yank it off. It might cost you $20.00 bucks but if they screw something up, not your issue.
Old 02-27-2008, 08:49 PM   #5 (permalink)
closest arctic cat dealer is 50 miles away.......
Im probally gonna drop the engine back in and get it running, you can pull the crank seal with the engine installed. I pulled the other side apart and replaced that seal.
2003 Yamaha R6
Old 02-27-2008, 09:27 PM   #6 (permalink)
Buy the puller tool. Cheap investment for a lifetime of use.
Old 02-28-2008, 06:58 AM   #7 (permalink)
IndianRvrShiver's Avatar
X2 !!!
Old 02-28-2008, 06:58 AM   #8 (permalink)
JDS
JDS's Avatar
I've heard of people pulling the clutch by filling the hole with either grease or water and then using the 3/4" bolt with an impact wrench. It pops the clutch off hydraulically.
JD
____________
2001 Arctic Cat ZR500
JDS is offline   Reply With Quote
Old 02-28-2008, 10:56 AM   #9 (permalink)
thats similar to how you remove the bearing in a clutch in my camaro!! I'll try that asap. Thats the kinda info these forums are good for, thanks a ton!
2003 Yamaha R6
Old 02-28-2008, 12:25 PM   #10 (permalink)
Let us know how that works out for ya'..........
Old 02-28-2008, 01:13 PM   #11 (permalink)
not too well......its pretty stuck, I doubt its ever been off before. I put the knipco on it, hopefully its warmed up by now. Im going back out to try it.
2003 Yamaha R6
Old 02-28-2008, 03:32 PM   #12 (permalink)
baaa stupid thing........It wouldnt budge. I dropped the engine back in and started hooking stuff up.........Any tips to get the cylinders down over the rings?? I 'm getting a buddy to come over, 2 hands dont seem to be enough.
2003 Yamaha R6
Old 02-28-2008, 06:36 PM   #13 (permalink)
05polaris550's Avatar
I would buy a ring compressor tool you can get them at an auto parts store...ive broken several rings not using one lol.
05polaris550 is offline   Reply With Quote
Old 02-28-2008, 07:18 PM   #14 (permalink)
It can be done by one person.
I have always started the piston into the cyl and then attached the wrist pin. Just make sure that you have it in the right way.
Old 02-28-2008, 08:32 PM   #15 (permalink)
oh geez guess what? I tried putting the cylinders on after the pistons were installed, no way would the cylinder slide on. I took the pistons off, and finally got the right cylinder & piston all bolted up nice and pretty.
THEN I snapped a ring on the left piston while trying to get the piston in the cylinder. The stock rings wont fit these wiseco pistons.....so I gotta get some new rings. These engines are ghey how the headbolts dont screw into the block like my atv engine. These are always in the way.
snow will be gone by the time I get this stupid POS together
2003 Yamaha R6
Old 02-29-2008, 07:18 AM   #16 (permalink)
It gets frustrating when you don't use the right tools or the right parts!!
Old 02-29-2008, 10:11 AM   #17 (permalink)
Maybe a stupid question, but I had to take the cylinder heads off my Polaris 700 engine recently... am I going to have a really hard time getting the cylinders back on over the pistons due to the rings? I could do one at a time and that might help as far as having enough hands... any thoughts?
Oh and I completely agree with IndianRvr... if I had the right tools in the first place I wouldn't have had to take the cylinder off.
stepper459 is offline   Reply With Quote
Old 02-29-2008, 10:51 AM   #18 (permalink)
put the pistons in the cylinders first, then side the cylinder and piston down and connect the rod to the piston. its a biotch to get the cylinder on when the pistons already hooked up.
2003 Yamaha R6
