Difference between cdi box and ignition coil? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 02-20-2008, 10:07 PM   #1 (permalink)
FORGET WORK- I WANNA PLAY
TCOLLINS's Avatar
Question Difference between cdi box and ignition coil?
whats the difference between cdi box and ignition coil?
1998 Polaris Indy 500
1996 Yamaha Vmax 600
1991 Yamaha Phazer II480
1986 Yamaha SRV 540*Freebee*
Old 02-20-2008, 10:30 PM   #2 (permalink)
Old Man's Avatar
Simply put, the ignition coil provides the voltage for the spark, the CDI box controls the release of that voltage.
Old Man is offline   Reply With Quote
Old 02-20-2008, 10:44 PM   #3 (permalink)
ENR_Kyle20's Avatar
I dont know if I can answer your question exactly. But The spark you see is a result of induction. There is 2 coils wound in very close proximity, one is the primary, and the other is the secondary. On a standard Ignation coil there is 12 volts applied to the primary coil at a certin time before spark is needed. Then when spark is needed the voltage on the primary coil is cut off. This causes the magnetic field to drop. the motion of the magnetic field droping induces voltage into the secondary coil wich is directly hooked to your spark plug.
from what I understand on a CDI sytem (capacitive-discharge ignition)they use a capactior on the primary side. So now its got more than 12 volts on the primary side wich induces even more into the secondary winding wich leads to a better spark.
I did a little research and found this.
CDI vs Inductive Ignition systems
Apparently CDI will spark stronger (Across a bigger gap) but the dwell is much shorter. So its good for a dirty engine. Or somehting that will have a hard to light mixture sometimes. but not ideal for everything
1996 Polaris Indy 500 SKS
Fresh Rebuild 12/1/07
Parts Unlimited Pistons/Rings
Bored 30/1000's
Shaved Head
3" Bar Riser
2,200 Miles
(Dont Forget To Grease Your JackShaft Regularly)
ENR_Kyle20 is offline   Reply With Quote
Old 02-20-2008, 10:45 PM   #4 (permalink)
TCOLLINS's Avatar
Are they both 1 piece?
Old 02-20-2008, 10:49 PM   #5 (permalink)
TCOLLINS's Avatar
very nice info. I am wondering if I have an ignition coil on my sled or just a cdi(C.D.Ignition) I have weak spark on 1 cylinder and ordered a new CDI Box. I am hoping this is what I need? I know I have a CDI box now.98 polaris indy 500
Old 02-21-2008, 09:12 AM   #6 (permalink)
The CDI (Capacitive Discharge Ignition) controls spark for the coil, and the coil sends it to the plugs. You need a coil, not a CDI. Follow your plug wires backwards, they go into the coil. The small wires coming out of the coil go to your CDI.
Old 02-21-2008, 05:08 PM   #7 (permalink)
TCOLLINS's Avatar
I am totally confused. My plug wires go into a piece called C.D.Ignition(CDI Box?)From there they go to the bottom of the motor.The C.D.Ignition looks like this picture.I don't see a coil anywhere. Unless it is inside the motor.This part here is the one I ordered. It goes to the spark plugs. The other smaller wires go to the motor. Maybe that is where the cdi is?
Old 02-21-2008, 05:15 PM   #8 (permalink)
TCOLLINS's Avatar
Smallengineguy Maybe I am calling this part the wrong name. At this point the part is on the way. What ever it is called I hope its right.Please take a look at the picture and see if it's a coil?The part In the picture above says C.D.Ignition stamped on it when I pulled it off the sled.
Old 02-21-2008, 11:58 PM   #9 (permalink)
Brian
Homey88's Avatar
That looks like what you need, its all conained in the CDI you orderd, from there it gets it signal from the stator.
2000 XC 600 Deluxe,45th Anniversary Edition, SLP Boost Bottle,X-tra 12,144 Studs.
1997 Indy 500,Custom Paint,96 Studs
Homey88 is offline   Reply With Quote
Old 02-22-2008, 06:28 AM   #10 (permalink)
Some of the POoo used a all-in-one CDI/coil unit.
More expensive to replace.
Old 02-22-2008, 08:04 AM   #11 (permalink)
JDS
JDS's Avatar
All in one; that's the right part. North Dakota, Suzuki, Polaris, Victory, Vespa, Piaggio, ATV, motorcycle, Scooter dealer, Action Motor Sports
JD
____________
2008 Polaris RMK 600-155"
2001 Arctic Cat ZR500
JDS is offline   Reply With Quote
Old 02-22-2008, 09:49 AM   #12 (permalink)
Mountain Man
lowbudget's Avatar
Yup it's all one unit. I just did the one on my girlfriends sled. Polaris wanted 250.00 for one, plus dealer didn't have it. I got mine at my local bike shop from WPS as Parts Unlimited didn't show one. It was only 125.00.
As Red Green says "Keep your stick on the ice." Thanks Mike
lowbudget is offline   Reply With Quote
Old 02-22-2008, 04:27 PM   #13 (permalink)
TCOLLINS's Avatar
Okay now it makes perfect sense. I thought I was losing my mind.
