01-23-2008, 07:38 PM
GO GREEN OR GO HOME!
exhaust paint
even the arctic cat exhaust paint wont hold up, what kind of paint can i use on my pipe?! im at a dead end....
2004 F7 SNO PRO 1.5K
2002 ZL 550 1.2K
2002 Z 440 1.4K
1990 SKI DOO SAFARI 377 6.5K
2001 ZR 600 CARB
(PARTING- NEED PARTS? GET AT ME!)
2003 ARCTIC CAT ZL 600 EFI 4300 MILESSOLD 8/09
1997 ARCTIC CAT EXT 580 EFI DLX 4000 MILES-SOLD 8/08
1998 ARCTIC CAT ZR 600 EFI-3700 MILES-SOLD-9/07
1996 INDY CLASSIC 500 ESR-5100 MILES-SOLD 4/08
1987 SKI DOO FORMULA MX 470-12000 MILES-SOLD 12/07
01-23-2008, 09:35 PM
USe stove black, it is cheap and you can recoat as often as you like.
Flagstaff, AZ Elevation 7000 feet
97 Indy XC 600, 136 Track
93 Indy Wide Trak
79 Yamaha Exciter
01-23-2008, 09:40 PM
2nd Assistant Highjacker
BBQ paint works aswome alot of its in the prep work too dude taker down to bare metal and they scuff it up really good with steal wool or a wire brush wich ever u prefer
Real men Hijack threads
-1995 zr580- aaen pipe, epi clutch kit, camoplast ripsaw/120studs, 3inch riser, flybars, upgraded foxshocks, weisco pistons, lightly ported, 19tooth top 32thooth bottom  soon to come bored carbs, plastic skis, new helix and ramps  BRAAAP
01-23-2008, 09:52 PM
BBQ and Stove paint....like said above.
Make sure its 2500 degree+ or it will burn off.
Nice sig...lmao go big...hahha bbw?
01-23-2008, 10:32 PM
There is a local guy here that says he has high temp powder coat?
11-01-2008, 08:59 PM
The secret is prevent the rust before it happens. I have an 95 Arctic Cat and the pipe still looks like new. Every year, before I put my sleds away, I spray wd40 all over everything under the hood including the pipe. Still looks like new.
11-01-2008, 09:46 PM
anything high heat and if you have rust scrape the loose crap off and use some naval jelly to "prime" it then put a very high heat paint over it....if you just painting on rust nothing will stuff for very long
I BLEED GREEN
2002 ARCTIC CAT ZR 500
1999 ARCTIC CAT ZL 500efi
1993 SKI DOO MACH 1
11-01-2009, 02:10 AM
twins rule!
hi heat paint
I just knocked off the loose stuff and sprayed it with cooking spray let it soak in and run it. it will smoke +smell a little, then slowly bake to a nice black that stayes shiney like a cast iron skillet cost 1.65 a can, recoat any time. Ihave done this to my wood stoves for years in the off season. my pipe was rusted bad when bought last year ,after 500 miles and sitting all 3 seasons it is shiney black. another light coat and smell the popcorn,
11-01-2009, 07:16 AM
Hmm I like that Idea! Could you do that with the WD40?
I like that Avatar too!
11-01-2009, 07:58 AM
this is a great idea- cooking oil on pipes
Petroleum based oil won't work because it is formulated not to break down with heat. Cooking oil "burns" when it gets too hot- and turns black and forms what is essentially organic teflon, the stuff that coats cast iron skillets, stoves, etc, and protects from rust. I just wish I thought of that years ago. I have spent hours each fall wire brushing and stove painting my pipes on 3 or 4 sleds- time I could have spent on more important preparations/repairs/upgrades. I'm definitely going to try the cooking oil trick this year!
11-01-2009, 11:36 AM
twins rule!
ac
if you put it on to heavy, it will take longer to season and stay a little tacky to the touch, but if you ride alot of miles this should not be a problem.
11-01-2009, 12:57 PM
That is a great idea! Never would have thought of it.
The path less taken has thy best powder!
11-01-2009, 02:38 PM
Farmaloose, so you are saying cooking spray such as the aerosol non-stick stuff like "Pam"??
Interesting idea!
11-01-2009, 03:50 PM
twins rule!
Bc
YES JUST LIKE PAM ,I use the cheap stuff from the dollar store but one can will last forever, so you could spring for the best and spend 4.00 vs 1.65 this time I think mine has olive oil in it so I guess my sleds are blessed. THEY MIGHT NEED IT
