01-22-2008, 07:34 PM
Belt slips when breaking fresh snow?
Is it possible for the drive belt to slip in the clutches? If I am breaking a new trail with fresh snow/powder, it acts like thats the case. Any ideas on stopping this?
Thanks
92-v-max4
01-22-2008, 07:42 PM
Did any oil get on the clutch? How Old is the belt?
87 TOYOTA 4x4
08 Yamaha Grizzly 700 fi eps
07-08 Season total 841.2
Clowns to the Left of Me ~ Jokers to the Right
http://www.atv-forum.com/
01-22-2008, 07:44 PM
If you get water on it, might make it slip.
Or maybe your tracks spinning, and you think its the belt? Idk....
01-22-2008, 08:10 PM
If there is a hole somewhere spraying snow onto the clutch it'll get wet and slip. Maybe thru the cowling or tub. Plug a hole or some sort of screen kit will help.
01-22-2008, 08:37 PM
Sconnie
mine has the exact same problem. the snow is coming in somewhere (i think through the hood vents or at base of hood) and the snow is packed into the engine bay. It steams, and melt away, but more obviously gets in. then all the water sits down by the clutch, and it slips a lot. could i drill a small drain hole?
i will eventually put screen over the hood vents, but we usually don't have this much powder (we got over a foot of powder yesterday on top of the 1 foot base).
otherwise, what else can you do to stop the belt from slipping?
~If you dont think it's bad @zz, then whats the point?~
1990 Skidoo Formula MX 470
1986 Ford Ranger 2.9L 4x4
3"body lift
3" Skyjacker suspension lift
dual custom exhaust
01-22-2008, 08:55 PM
That is the most common problem with sinking sleds while waterskipping also. The clutch just cannot get snow or water on it, else you loose pull till it drys out. Plugging holes or screening them on the clutch side is the only way to go if nothing else most cowlings have holes for screws and kits, you can use store bought screws with washers, and some window screen for some temporary/cheap snow screens, while the powder is there, then take them off when alls back to usual. And also a little silicon goes along way, and it's cheap and easy to clean up.
01-22-2008, 09:26 PM
GO GREEN OR GO HOME!
snow has to be getting in somewhere. once the clutch gets wet itll slip/loose power. check under your belly and check/seal any potential breaches. maybe some hood screens if you dont have em.
2003 ARCTIC CAT ZL 600 EFI SS-2700 MILES-GETTING SOME MILD TWEAKING THIS SUMMER
2002 ARCTIC CAT Z 440 ES-622 MILES-MINT, JUST LOOKING FOR SOME STUDS AND FATBOY TORSIONS.
1997 ARCTIC CAT EXT 580 EFI DLX 4000 MILES- SOLD 8/08
1998 ARCTIC CAT ZR 600 EFI-3700 MILES-BUILT- SOLD-9/07
1996 INDY CLASSIC 500 ESR-5100 MILES- SOLD 4/08
1987 SKI DOO FORMULA MX 470-12000 MILES- SOLD 12/07
01-22-2008, 09:52 PM
Sconnie
ok. i know the belly pan is all good, but the nose cone is missing. so maybe it's coming in there. or in the vents, we had a lot of powder. and once all the powder and water was in there, it kept getting it wet so it would slipo even when you were on a good trail.
what would you do with the silicon though?
3"body lift
dual custom exhaust
01-24-2008, 06:55 PM
Here is a picture...do you think this is enough snow to cause the problem....if so...any idea where its getting in at?
01-24-2008, 07:09 PM
Alaskan Member
Absolutely enough snow to cause the problem. Check all your left side vents. Is your hoos sealing well around the mating points? How about behind the hood, any new vents or missing peices there?
1980 Polaris TX-L 340 - Stock
01-24-2008, 07:21 PM
have someone shine a flashlight from the outside all over in the dark, and where it shines through, investigate. maybe some type of mesh screen, thats a ton of snow by the clutches.
01-25-2008, 03:21 PM
My compartment looks worse than that when I am busting deep powder (5+ feet)
I have the same issue and all my stuff is sealed and theres screens.
Co Springs Co
1999 Powder Special 700 1500 miles
1999 Powder Special RIP
2003.5 Mountain Cat 900 Mod Sled
1998ish zr600 In the mad scientists garage getting some new guts and mods...Should be interestin.
01-25-2008, 03:48 PM
Sh!tn'n'G!tn
If you are in that much powder even screens won't be enough to keep the powder out. You almost have to cover the vents completly. The only problem is you risk overheating then.
'94 Polaris XLT SKS
01-25-2008, 04:44 PM
Alaskan Member
I used to have a bib on my old '91 Indy 500 that worked GREAT for those conditions. Wish I still has that sled...
Screens help out though, especially if the snow is a little wetter.
01-25-2008, 04:54 PM
I've used colored duct tape!
01-25-2008, 04:56 PM
Sh!tn'n'G!tn
Thats what I used on my old sled but it is a b!tch to get off.
'94 Polaris XLT SKS
