Originally Posted by RJ Gleason
That's if you are going to attempt a total overhaul of the clutch.
In his case, he only needs to pull the end plate to remove the spring so that he can change the rollers and weights.
Are we talking about the same rollers? The rollers I am talking about are the ones in the spider that the weights ride on. They are captive between the towers. To get them out, the spider needs to be spun off. The pins and bushings that the weights pivot on can be replaced with the spider in place.
Its the rollers in the spider that are hard to replace and are
expensive. These are the ones that tend to flatten out and cause erratic shifting.
Hope this is of some help.
