01-19-2008, 05:25 PM
running my sled below zero
its below 0 here in minnesota today. i was riding out on the lake and i thought i could hear some missfiring or a slight pop as i was riding 1/4 throttle slowing down. maybe i only herd it because i was paranoid and knew that the cold temps would make it run leaner. im pretty sure that it has its stock jets in it. the plugs where jsut slightly lighter than color of cardboard. usually they are cholotale brown with tan tips at the very end. should i wait till it warms up or can i ride it without worrying?
'94 Arctic Cat EXT 580
01-19-2008, 05:31 PM
Running sleds at 0 is great, i ride in all tempatures as long as it isnt below -20 because then i'd worry about myself freezing :P
I Love To Be Loud!
01-19-2008, 05:41 PM
2nd Assistant Highjacker
snowmobiles are ment to run in the cold why would they desgin a sled to run at +4"donest snow when its warm" you will not lean it out in 0 bout -15 celius
Real men Hijack threads
-1995 zr580- aaen pipe, epi clutch kit, camoplast ripsaw/120studs, 3inch riser, flybars, upgraded foxshocks, weisco pistons, lightly ported, 19tooth top 32thooth bottom  soon to come bored carbs, plastic skis, new helix and ramps  BRAAAP
01-19-2008, 07:01 PM
thats good to hear. i guess i was just being cautious.
01-19-2008, 07:16 PM
If your really worryed mix your gas 40:1 if plugs go black 50:1
01-19-2008, 07:20 PM
im worried about oil. just if im lean on the gas.
01-19-2008, 07:29 PM
how could you be lean on gas lean =more gas than oil rich= more oil than gas if your worryed about leaning it out run premix and diconnect your oil tank for the time being!
01-19-2008, 07:38 PM
Lean means too much air for the amount of fuel. You can burn an engine down at 20:1 . If you have enough air to ignite 100% of the fuel in engine, then engine has no oil left to lubricate and....BOOM! More oil will maybe help for a minute, not in the long run. That is why temperature plays a facture in burning down an engine. Cold air is more dense and thus has more oxygen, more oxygen burns more fuel. Stock jets should be good to 25 below without a problem, but with downsized it become more risky.
99XC600
98XTC700
00SXR700
01XC340
01-19-2008, 10:32 PM
You need to know what jets you have in your carbs. Cats have a jetting chart on them that shows what jets to run at what temp and altitude. That chart is a good guideline, but reading your plugs gives you a more accurate picture of what jets you should be running. I've run my ZR down to -20 no problem using the jets on the chart. I run my EXT at 2 sizes lower than the chart, and it's been fine for over 4,000miles. I keep a logbook showing what jets work best at different temps and altitudes as well as clutch weight sizes, clutch spring colors, etc.
JD
____________
2001 Arctic Cat ZR500
1991 Arctic Cat EXT SP 550
1991 Honda Fourtrax
01-19-2008, 10:38 PM
2 Things to do, increase the main jet one size and raise the needle(lower E clip)!
They do make a controller that you can adjust the flow rate! Holtz makes the veri flow!
01-20-2008, 05:25 AM
Above The Arctic Circle
I run my sleds at -30C witch is around -20F to -25F. Anything colder than that and its just miserable to ride anyway. Rejet if you need to and youll be fine.
01 Polaris RMK 136"
- 01 600 VES Engine - Uni Air Filters
- Sno Stuff Rumble Pack - Powermadd Boost Bottle
- Custom Painted Hood - Powermadd Bar Riser
- EPI Pro Series Clutch Kit - Xtra-10 rear suspension
01 Yamaha VK III 540 ( The TANK)
Out Of Commission Till Next Year
01-20-2008, 10:05 AM
Find a temperature / altitude / jet chart for your sleds engine. From -30 to 0 mine takes a .280
I didn't claw my way to the top of the food chain to eat vegetables!
1980 John Deere LiquiFire
1990 Polaris Indy 500
1993 Polaris Indy Trail
1996 Arctic Cat 340 Puma
