Old 01-19-2008, 08:15 AM   #1 (permalink)
maiden9494
maiden9494's Avatar
adjusting 2ndary clutch for belt.
i posted a thread about a week ago about this but never got no replys .. does anyone know how to adjust the secondary clutch right ?? just tell me is this wrong : when you get a new belt the flat top of it should be flush with the drive pully edges . and then you put the adjust things on the outside which is numbered from 0 to 6 back to 0. as the belt stretches you eventuallly move it up a notch each time towards the 6?
-04 mxz-x 600 sdi xps-II
-07 mxz-x 550
-02 mxz 380
-06 yz85
maiden9494 is offline   Reply With Quote
Old 01-19-2008, 10:50 PM   #2 (permalink)
kccats
What sled? On Cat the belt rides out of the secondary an 1/8 to 3/16th! To adjust you remove shims from between the sheves! Keep removing till it starts to squeel, then put a thin one back! They do make a belt adjuster that can be adjusted in the feild as the belt wears!
Old 01-19-2008, 11:07 PM   #3 (permalink)
maiden9494
maiden9494's Avatar
its a doo . 04 mxz -x 600 ho sdi
-07 mxz-x 550
-02 mxz 380
-06 yz85
