Old 01-18-2008, 12:03 PM   #1 (permalink)
eriksat1
eriksat1's Avatar
Chaincase Oil "Ok I will eat Crow"
I was on some other threads saying how I always use 80W 90 gear oil in my chain case and never had a problem, but I am now eating crow and switching to synthetic chain case lube. Here is what made me change my mind. A service bulletin from John Deere a long time ago. They used to always recommend SAE 90 in JD LiquiFire's in the early 1980's.
O.M.-M67673/79 for 1978 Cyclone/Liquifire recommending SAE 90 if oil must be added
O.M. for 1979 Trailfires neglected to indicate oil type but the 1980 O.M. continued with the SAE 90 recommendation
O.M. for 1982 Models specificly recommend API-GL5 (SAE 90)
Service Information Bulletin From John Deere M81-50-9
Problem: SAE 90 oil does not always flow during initial operation in colder snowmobiling temperatures
Solution: Use J.D. Hy-Gard TY6237 or ATF in chain case.
This is what I was told by an old JD mechanic
"There is a synthetic chain case lube that is preferable for all chain cases silent or not. Use this in place of oil."
"In case someone is wondering, 90wt gear lube in cold temperatures doesn't lubricate. Evidence of this problem is shot or seized chains, worn or broken toothed gears, melted bearing seals, loose bearings not cause by rust, and of course shot tension adjusters. Extreme damage may occur to case if chain snaps and or bearings disintegrate."
Enough said. I'm eating Crow. I am switching to the synthetic chain case lube.
I didn't claw my way to the top of the food chain to eat vegetables!
1980 John Deere LiquiFire
1990 Polaris Indy 500
1993 Polaris Indy Trail
1996 Arctic Cat 340 Puma
eriksat1 is offline   Reply With Quote
Old 01-18-2008, 12:05 PM   #2 (permalink)
BC_Dan
Yep, you can get away with gear oil, but snowmobiles don't have gears, they have sprockets driving a chain, gear oil is too thick for sprockets
Rebuilding the fleet!
Old 01-18-2008, 01:00 PM   #3 (permalink)
Good times. Welcome to the club.
Old 01-18-2008, 01:22 PM   #4 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
Takes a big man!! We all do it at one time or another....like SEG said, "Welcome to the club!!"
Old 01-18-2008, 01:48 PM   #5 (permalink)
ethan31
ethan31's Avatar
Well damn, i had the syn lube and everyone said to get 80-90w gear lube so i did. Now what?? Whats a good lube? For cheap, the local dealer has xps synthetic for $18-12oz.......that is crazy.
ethan31 is offline   Reply With Quote
Old 01-18-2008, 03:05 PM   #6 (permalink)
BC_Dan
Lots of people use ATF, it works great in transfer cases for 4x4 trucks. Cheap, too! My personal belief is that you can probably use just about any type of oil in there, as long as it is thin enough to lubricate properly in really cold conditions and you check it often to make sure it's not low. I put chaincase lube in mine this year, probably going to go to ATF next year.
Old 01-18-2008, 04:03 PM   #7 (permalink)
eriksat1
eriksat1's Avatar
Ethan31 you can order this from manufactures supply. This is a 12 oz bottle for $6.99 your chain case probably only takes about 6 ozs. Here is the link. SPEC-CCL - Spectro Full Synthetic Chain Case Oil
Spectro Full Synthetic Chaincase Oil is designed to give your snowmobile maximum performance and protection, even at temperatures below -50 F. Lubricates all chains, bearings and roller bearings. Spectro's advanced formula prevents wear, rust, oxidation & foaming. Meets or exceeds manufactures specifications. Compatible with all mineral based oils. 12 oz bottle.
Suggested Retail Price: $8.00
Our Price: $6.99
Old 01-18-2008, 04:04 PM   #8 (permalink)
zakr84
i got 12 ounces of amsoil synthetic snowmobile/atv chain case oil from an auto parts store, i forget how much it was exactly but i know i wasn't anywhere near $18.
zakr84 is offline   Reply With Quote
Old 01-18-2008, 04:09 PM   #9 (permalink)
ethan31
ethan31's Avatar
Amsoil is like $7 on there site.
The reason i got the xps stuff is, its the only place around and i needed at the time. I about shit when they asked for $18. I googled it and online its like 8$.....robbers
Old 01-18-2008, 04:46 PM   #10 (permalink)
eriksat1
eriksat1's Avatar
Yea but add at least $6 for shipping and handling. I am ordering some but am also getting some other stuff with it like spark plugs so shipping is still $6
Old 01-18-2008, 06:05 PM   #11 (permalink)
BskidooC
BskidooC's Avatar
I always use 75w-90 fully synthetic gear oil. Never had a problem and will most likely never stop using it.
Old 01-19-2008, 02:08 AM   #12 (permalink)
lrnnorth
Above The Arctic Circle
lrnnorth's Avatar
I used to use the gear oil but I switched to ATF and it seems to do better.
01 Polaris RMK 136"
- 01 600 VES Engine - Uni Air Filters
- Sno Stuff Rumble Pack - Powermadd Boost Bottle
- Custom Painted Hood - Powermadd Bar Riser
- EPI Pro Series Clutch Kit - Xtra-10 rear suspension
01 Yamaha VK III 540 (The TANK)
Out Of Commission Till Next Year
lrnnorth is offline   Reply With Quote
Old 01-19-2008, 12:44 PM   #13 (permalink)
Ditch hopper
2nd Assistant Highjacker
Ditch hopper's Avatar
just good ole fastion ATF? i found like 6 differnent kinds last night at walwart
Real men Hijack threads
-1995 zr580- aaen pipe, epi clutch kit, camoplast ripsaw/120studs, 3inch riser, flybars, upgraded foxshocks, weisco pistons, lightly ported, 19tooth top 32thooth bottom soon to come bored carbs, plastic skis, new helix and ramps BRAAAP
Ditch hopper is offline   Reply With Quote
